Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Reg (guest)
Guest
Posts: n/a
Nick, turns out there are two grommets/rubber insulators that the two upper mounting pins go through...and the grommets/insulators DO NOT come with the replacement radiator...they must be purchased separately. See the two attached pics. So now, no more movement...mounting problem solved!
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-24-2014, 04:30 PM
Nick at Pelican Parts's Avatar
Yes, those grommets should be removed from the old radiator, if in good shape. If not, replaced. Glad you got it worked out.
- Nick
