Guest
Posts: n/a
Hi All at Pelican, i have just read this and it looks very useful.
The problem i have is the window does not drop that small amount when you open the door and seems jammed is this a symptom of the mech needing replacement Thanks __________________ This post was auto-generated based upon a question asked on our tech article page here: |
What kid of vehicle?
- Nick |
Administrator
Will it open at all? If so, it may simply have lost where it thinks the open and closed positions are. You can re-initialize the window by doing the following:
- Roll the window all the way down. Keep the switch down for another 5 seconds after it is open. - Roll the window all the way up. Keep the switch up for another 5 seconds after it is closed. That should re-set the open and closed positions stored by the car. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thread Tools | |
Rate This Thread | |
