Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Frustrated (guest)
Guest
Posts: n/a
Replacing rear brakes and rotors no problem. Went to replace the sensor. Found the sensor too short. Wont fit from brake to connector Store says its the correct one. I have a 2009 the sensor length is 44 incnes long end of connector to sensor.
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-06-2015, 04:58 PM
Nick at Pelican Parts's Avatar
I don't have anything to check the length against.
I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
914 Geek
44 inches total length sounds about right, at least for my 2012 model. Are you sure you're routing it correctly?
--DD
Old 09-08-2015, 07:27 AM
