Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Naazyd (guest)
Guest
Posts: n/a
Hi. I have a 2006 cooper s convertible with automatic transmission. Once my car is heated up the car battles to change gears, the revs peak past 4 then it changes hard with a bang. Do you suggest gearbox oil or buy a complete near gearbox?
Warm regards
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 09-15-2016, 06:09 AM
Nick at Pelican Parts's Avatar
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
