Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Bruce (guest)
Guest
Posts: n/a
R52 how to replace reverse light bulb
Thanks for the instructions. I have a 2007 mini convertible and found a video that showed how to access the tail light assembly. As someone already mentioned there's a small access door that you can barely fit a 10mm ratchet wrench into and take off the single nut then push the tail light assembly out after squeezing the clips. The video shows the steps. However, one thing I couldn't figure out is how to remove the reverse light bulb as on my 2007 it's different than the tail/brake bulb. In the video it's the same reverse bulb and I uploaded a picture as well. Anyone replaced this reverse bulb and want to share how to do it?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Lens and Bulb Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 11-10-2016, 11:07 AM
Nick at Pelican Parts's Avatar
We don't currently have that tech article. If we get a chance to perform the procedure, we will be sure to document it.
I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
Thanks Nick! I need to buy a good repair manual. Also, I can't remember if I pasted the link to the video or not or if that is allowed or not here but just in case here's the link to the youtube video at https://www.youtube.com/watch?v=-Cv9h3ic2JI showing the repair. I think it would be worthwhile to post the link so people can use both your article and watch the video as they both helped me in my repair!
Old 11-10-2016, 12:59 PM
Administrator
Luccia at Pelican Parts's Avatar
Bentley Manual here: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Books & Technical Documentation - Page 1. Might be doing a promo on them sometime in the near future as well.
If you took pictures and still remember in detail how to do the repair, might I suggest submitting it for our enthusiast content? Details at the link below. If yours gets selected it will be published in our tech library and you can get 10% off your next order with us.
Enthusiast Tech Article Submissions - Pelican Parts
Let me know if you have any questions.
Old 11-15-2016, 08:46 AM
