Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
T Small (guest)
Guest
Posts: n/a
how to fix my code P0014 on my 2007 mini cooper
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-14-2017, 07:04 AM
Nick at Pelican Parts's Avatar
Check the article you commented on. If that doesn't do it, check mechanical engine timing.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
P0014 - "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
Do you have hard starts or poor idling? Yes, attempt to remove the exhaust VANOS solenoid and checking if it is gunked up and clean it. You can also attempt to swap your intake camshaft sensor with the exhaust camshaft. See if it changes. If cleaning does nothing, replace it.
Updated part here from MINI: 2007 Mini Cooper Base Hatchback - VANOS Solenoid
Old 03-14-2017, 10:25 AM
