Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
KarterGene (guest)
Guest
Posts: n/a
R56 Mini. Replaced both rear calipers and master cylinder. Used motive pressure bleeder. Brakes work but holding pressure on the pedal allows it to go slowly to the floor.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Bleeding (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 07:33 AM
Nick at Pelican Parts's Avatar
Air trapped or faulty master cylinder. Try bleeding again.
- Nick
914 Geek
In my old Hondas, at least, this was the typical symptom of a failing master cylinder.
--DD
Old 04-19-2017, 08:52 AM
Administrator
Luccia at Pelican Parts's Avatar
Definitely try bleeding it again. Otherwise, long pedal travel is a sign of that one or more components of the system have failed. Review this article here: MINI Cooper Clutch Master and Slave Cylinder Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article.
Let me know what model R56 and I can help you with parts if needed.
Old 04-24-2017, 12:30 PM
