Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Phil (guest)
Guest
Posts: n/a
How can you determine when the rear shocks should be replaced?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Rear Shock and Spring Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 06-13-2017, 07:02 AM
Nick at Pelican Parts's Avatar
if leaking, high mileage for preventive, or if the rear end has excessive bounce.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
You might also hear a clunking type sound from the rear. It'll definitely be a bit more of a bump and most certainly feel like a much harsher ride. If you're replacing your shocks you'll also want to replace your shock mounts while you're in there.
Mini Cooper & Cooper S (R50/R52/R53) - Suspension, Shocks & Springs - Page 3
Old 06-13-2017, 08:33 AM
