Guest
Posts: n/a
What exactly am I looking for at the negative end of the cable for the IBS? I looked at Fig 7 as per a previous post, and my car has nothing but a plain wire to the negative terminal, ie. no L-shaped plastic unit, just the simple connection. Do I conclude then that my R56 does NOT have IBS? Thanks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
If your negative terminal lacks additional small wiring and a plastic housing, you do not have an IBS.
- Nick |
Administrator
Yep, you most likely do not have an IBS unit. If you want to have us double check, please post an image of your negative terminal for us.
Thread Tools | |
Rate This Thread | |
