Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
bin (guest)
Guest
Posts: n/a
have a 07 plate mini with n12 engine replaced timeing chain and vanos solenoid still got 2845 so replaced the unit on end of cam still same only exuhast cam would a cam sensor bring up same fault
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-08-2017, 07:15 AM
Nick at Pelican Parts's Avatar
Is that a P-code or BMW code and what is the fault code description?
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Did you clear the codes after doing the replacements? I'm assuming you mean P2845? That doens't show up in the Bentley Manual. Are you using a MINI specific scan tool?
Old 09-28-2017, 11:23 AM
