Guest
Posts: n/a
have a 07 plate mini with n12 engine replaced timeing chain and vanos solenoid still got 2845 so replaced the unit on end of cam still same only exuhast cam would a cam sensor bring up same fault
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
Is that a P-code or BMW code and what is the fault code description?
- Nick |
Administrator
Did you clear the codes after doing the replacements? I'm assuming you mean P2845? That doens't show up in the Bentley Manual. Are you using a MINI specific scan tool?
Thread Tools | |
Rate This Thread | |
