FUSHIGI
Originally Posted by Evans, Marv View Post
I'm still leery of the small engines in new cars with turbos & putting out high amounts of power. In my old mind, all that power adds stress to an engine reducing its longevity.
I think that the way in which a motor is stressed is important. A (relatively) slow turning, warmed-up turbo'd diesel (commonly running a forged steel crank and rods) feels and sounds really smooth compared to a faster-turing NA motor of similar displacement and comparable power (but often running much less robust rotating/reciprocating hardware).
Old 10-26-2018, 05:13 PM
There is much hype about an invention that solves the too small turbo problem.
Take a look at e-booster from BorgWarner. The electric turbo comes on for a few seconds and then the big turbo takes over. Mercedes S Class has this already.
Regarding more stress on the engine parts - let's assume the engine designers know this (duh) and change the design to meet the longevity requirements.
Sold: 1989 3.2 coupe, 112k miles
Old 10-26-2018, 05:40 PM
Only one moving part.
light weight rotor, precision balanced so very smooth at high rotational speeds.
Typically sleeve bearings lubricated by engine oil, circulated to carry away heat and prevent carbon buildup.
Relatively low pressures.
Some are also liquid cooled.
Some even has ceramic bearings but I'm not a fan.
Heat of exhaust is a concern but stainless alloys handle the heat on the gas turbine side, special elastomer o-rings to stand up to the heat, some have mechanical seals to keep the oil where it belongs and the oil carries away heat as does the air flow on the compressor side.
And as soon as you take your foot off the throttle the EGT drops quickly starting the cool-down process.
The oil is key. Gotta keep it clean, and I consider synthetic almost mandatory.
I've pulled turbos off junk-yard cars with over 100k miles, and repurposed the turbos onto other custom applications with no refurbishment at all and they worked just fine.
Taken care of they should last the life of the engine.
But if abused they turn into bic lighters.
I had a friend who bought an almost new 924 turbo a long time ago, against my advice.
He had a habit of driving fast down the street, putting it in neutral, and pulling the e-brake as he came to a stop and instantly hopped out of the car, looking cool.
I said don't do dat. He scoffed.
After replacing the turbo TWICE in two years he started to listen.
See as he was pulling up, the turbo was still spooled up and spinning really fast. He shut off the motor before it had a chance to slow down or cool off, which shut off the oil flow to the hot turbo and bearing, melting the sleeve bearings. And what oil was left in the turbo bearings cooked as it sat there cooling down, which caused damage when re-started.
Synthetic oil was not commonly used back then.
But he looked cool.
PS you never want the engine to reach stoich under boost, too lean. Hot. melted. ping ping.
Depending on engine and boost levels, 12 to 13.5 to 1 would be a lot safer.
Old 10-26-2018, 05:44 PM
brainz01's Avatar
I’m hooked on the turbskis. More power out of a smaller package and usually much more easily modified than an NA motor. That a stock 997 twin turbo Mezger motor, with nothing other than an ECU flash, can make over 200HP/liter while maintaining easy driveability still blows my mind. Not enough power? Beef up the pistons and rods and put some bigger snails on there and the Mezger TTs can easily double that figure again. Impressive (though likely not nearly as driveable or robust).
And with modern electronics, they only seem to get better. Lag is constantly being reduced from one generation to the next, so the new engines feel pretty much like much bigger motors of yore.
Also, many new turbos are also watercooled, so the bearing coking issues are not what they were 30 years ago. That said, I’d still run a quality oil and stay on top of changes...
I’m not sold on the new reverse-flow, valley-mounted turbos (like on BMWs and Mercedes). I get why they do it, but I question what lifespan those are engineered for — that’s a lot of heat in a small area on top of the engine.
But the Porsche stuff seems pretty bulletproof. Especially the 911s. But even on the original Cayenne TTs, many of which are approaching 15 years old and well over 150k miles, there are not many reports of turbo specific issues.
Old 10-26-2018, 05:56 PM
pwd72s's Avatar
Ironic because on my list is a Mustage ecoboost
But everything from Hyundai to VW seems to be going to turbos.
I know how they work, just wondering how long they work.
Go with the 5.0. You'll get longer life and still decent MPG with adequate power over a flat torque curve.
Old 10-26-2018, 06:17 PM
canna change law physics
red-beard's Avatar
If you just stick a turbo on a small engine, you will do exactly this. But today, the engines are beefed up to handle the higher pressure charge. Just do not play with the waste gate settings.
My 6.2l Ford can be "lightly" turbocharged to 600hp, with only 7-8psi of boost. 15 will basically double the output. I have no need....
James
Red-beard for President, 2020
Old 10-26-2018, 06:24 PM
Unregistered
sammyg2's Avatar
BTW, you can't turbo a 914.
Old 10-26-2018, 06:38 PM
Banned
shouldn't maybe
but a fair number of people have
others sell kits
https://www.google.com/search?q=vw+type+4+turbo+kit&ie=utf-8&oe=utf-8&client=firefox-b-1
there are pictures too
Old 10-26-2018, 07:08 PM
I like the somewhat elegant idea of the economically won force derived from turbo charging. I think, from a reliability standpoint, on modern turbos is that they do run hot and expose all your engine bay bits, sensors, pumps etc to more heat which could shorten lifespan.
Old 10-26-2018, 07:10 PM
Just the latest example of legislation driving engineering. Turbos make it easier to hit mandated fleet emissions and mileage requirements.
The government outlined tests for these parameters are set up to favor small displacement turbo motors running off boost. On boost they are dirtier and thirstier than normally aspirated, larger displacement engines, but that is not how they are currently certified. Part throttle acceleration and part throttle cruising are the current test parameters. They are essentially "fooling" the test with a small displacement engine running off boost.
Modern turbo motors, in run of the mill sedans and such, are actually reliable, long lived, trouble free powerplants that meet most drivers' needs. A lot of us hear "turbo" and immediately think of fire-breathing, hairy chested he-man monsters. Such is not the case anymore. While we can still buy those and have fun with them, turbos are now mainstream minivan, SUV, mommymobile technology. It works, it's reliable, and most importantly, it passes the tests. Legislation driven engineering at its finest.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 10-26-2018, 07:39 PM
Arizona_928's Avatar
Very common in the type 1/2, and type 4 for a turbo power adder.
Very common.
dolor et pavor
Copyright
Old 10-26-2018, 11:30 PM
David's Avatar
As much as I like the high rpm scream of a naturally aspirated engine, it's hard to beat the current generation of the turbo gasoline engines. My son's VW Jetta gets great mileage and pulls pretty well from almost any RPM with its 1.8 turbo. My 930 on the other hand feels like it has no power until about 3,000 rpm and then Katy bar the door!
Old 10-27-2018, 05:20 AM
red-beard's Avatar
Very common.
Sammy is being facetious.
James
Old 10-27-2018, 05:33 AM
Turbos are the way! Keep the oil fresh (don't scrimp on oil changes), cool them down and they will last forever. The power is addictive.
Old 10-27-2018, 06:06 AM
id10t's Avatar
Porsche too? Read an article awhile back that has forced porsche to use turbos in EU to meet the emissions requirements.
Somewhat ironic that the 930 couldn't be brought in to the US in the mid80s due to Cali emissions laws... hence the M491 optioned cars.
Old 10-27-2018, 06:20 AM
pete3799's Avatar
I've never owned a car with a turbo but have put more than 3 million miles on turbo charged diesel trucks (Cummins and Caterpillar) and have never had to replace a turbo. Never used synthetic oil always Shell Rotella 15/40.
I did replace the turbo on my F-550 (6.0) when i bought it because it had sat for 2 years with a bad transmission and the variable vanes inside it had rusted and pitted.
Always amazed me that something that runs at 800-900 degrees and spins as fast as they do hold up so well.
Pete
79 911SC RoW
Old 10-27-2018, 06:24 AM
red-beard's Avatar
I installed, operated, designed, etc. Gas turbines. 1 moving part. And the temps were as high as 2450F
James
Old 10-27-2018, 06:30 AM
Information Junky
island911's Avatar
This!
Porsche has stopped making V8's (think Cayenne, Panamera 928) but now you can spend the same on a 4-cylinder turbo'd Macan.
Of course the peak output stresses are more focused on blown-4, than a NA-8. Which means longevity will likely take a hit. But life of the vehicle is not a controlled metric in the "green" math.
Old 10-27-2018, 06:51 AM
red-beard's Avatar
Originally Posted by island911 View Post
This!
Not if you design the engine to be turbocharged from the beginning. The 930 engine was designed around being turbo charged. The SC benefited, since the 3.0l engine was basically the same as the turbo engine, without turbos.
James
Old 10-27-2018, 07:00 AM
Control Group
Tobra's Avatar
I had a Honda with the magical VTEC head on it, 8000+ redline, visited regularly, intoxicating little sedan. It was killed by a minivan...
Got a Miata because I missed the ragtop. They are pretty dinky, unless they are sitting next to a Spitfire, then they look huge. If you are over 6', you maybe won't fit. The turbo one had the strongest of everything thing and the best limited slip they used, so I got that one. I put an intake on it because that was about all you could do to it in California. Woke it up some, and now you hear the bypass valve, which is cool. Will need to replace the cat pretty soon, and there is a street legal high flow one available now, at half the price of the OEM. It won't last as long, but it is significantly lighter, and will put me at right around 200 hp to the rear wheels in a 2350# car with a decent independent suspension and a 50:50 balance. All that, and it has air conditioning that works.
Old 10-27-2018, 07:37 AM
