The Unsettler
stomachmonkey's Avatar
Yeah, I dunno about this.
"I want my two dollars"
"Brandon Won"
Old 11-29-2018, 07:27 PM
A930Rocket's Avatar
Hmmmm..,
What happens if you go too far?
Old 11-29-2018, 07:45 PM
Navin Johnson
TimT's Avatar
I have one of these, pretty handy actually.. a lot quicker than dragging out a jack to change a flat on a trailer etc.. If you over drive it all that happens is wheel lands back on the ground and the thing falls over.. Still need jackstands for more involved work.
'69 911 GT-5
'75 914 GT-3
and others
Old 11-30-2018, 03:24 AM
Did you get the memo?
onewhippedpuppy's Avatar
Don’t have to worry about gas tanks on a trailer. I think that’s cool as hell, I might grab one to keep in my truck when I tow my boat.
‘07 Mazda RX8-8
Old 11-30-2018, 03:51 AM
Originally Posted by afterburn 549 View Post
That is what I did mean-"some applications".
I would not try it on the car.
It looks to only work on a solid axle, which would limit it to pickups, Jeeps, and old school SUVs.
‘07 Mazda RX8-8
Old 11-30-2018, 04:43 AM
Zeke's Avatar
Yeah, might be too tall for your Jetta.
Old 11-30-2018, 05:05 AM
I may look at getting one for my 30' camper...put a block of wood under it so it doesn't sink into the ground, and slowly roll it forward to elevate. It would save havng to carry a heavy jack.
Old 11-30-2018, 05:12 AM
If you have a 2 axle trailer you can drive up on a couple of 2 x 4's under one tire and raise the other tire off the ground. BTDT.
Old 11-30-2018, 08:21 AM
Platinum Member
dad911's Avatar
Looks handy for a trailer. I've done as Paul said, problem with a 2 axle trailer is sometimes a road hazard wipes out both tires.....BTDT . Then I'm not sure the axle jack would work.
The truth is that while those on the left - particularly the far left - claim to be tolerant and welcoming of diversity, in reality many are quite intolerant of anyone not embracing their radical views. - Charlie Kirk
Old 11-30-2018, 09:08 AM
Navin Johnson
TimT's Avatar
I think the driving up on plank trick only works on trailers with Dexter torsion axles.. With leaf springs the other wheel stays on the ground...Had to change a shackle on a tripe axle leaf spring trailer recently when we jacked the axle with the cracked shackle to remove the leaf spring, the other two axles drooped was being raised
'69 911 GT-5
'75 914 GT-3
and others
Old 11-30-2018, 12:39 PM
