I'm not looking for extra speed. I just really like the way the SRAM double tap shifters work. It's, to me, much simpler than the Shimano stuff (which is great). I don't feel line I need to swap the front since I shut so much less up there. And it was a little bit curiosity about the differences between the systems and how important it is to match the front and rear. It sounds like the match of the front and rear is not that important other than to ensure that the chain will work with both. I think the one other considering would be that the brakes (disc in my case) will also work with the brifters.
The 9 Store
So the whole system is designed and spec to work together and often times, a large manufacturer like trek or specialized will have shimano build a component to their spec but not be made available to the aftermarket. We often had people who purchased components in an attempt to upgrade, bring their bike in because it ran worse than with the old stuff. That was 20 years ago. The situation is even more difficult now. Then you add in new components to an already worn system and the trouble is compounded. At the very least, ask your local bike shop geek if what you are buying will work with what you have.
All used parts sold as is. Last edited by mepstein; 01-17-2019 at 11:58 AM.. |
