PPOT - Braintrust question.
i'm gonna unplug our office alarm backup batter and plug in a new one.
some cheapo HoneyWell system. shows low battery. this is for my office. to do it officially - i need, official request from 3B-1254-(rev.2.0), sent in triplicate, approval forms returned in triplicate with wet signatures, peer review, 3 lowest bids, mock set ups, dry runs, contingency plans.... the battery is $21 bucks on Amazon. i'll take a long lunch break as compensation. ![]() how may ways can this go wrong? i cant see a reset button. i could jump it and keep the system seeing voltage the entire time..i think i saw how he did it on that movie "HURT LOCKER" figure i'll run it by you all before i cripple my work office because we hate paperwork. thanks.
poof! gone |
i cant believe there's me on this forum, and there is a dude rebuilding a Class A RV from scratch..
poof! gone |
I wouldn't do it ... could loose settings, etc. How farked would you be if Things Went Wrong and "They" found out you were responsible?
File work orders, email the boss, whatever. Make it someone else's problem. |
It's a backup battery, right? As long as you maintain power to the system, replacing the battery should be a non-issue. Look up instructions for your particular model on Google or YouTube.
Guy '87 944 (first porsche/project car) |
Vash - don't forget the TPS report when you are finished!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Band.
Google it then just do it
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Is it a vista system?
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
Unplug old one. Plug in new one. Done.
If for some strange reason it triggers the alarm, quickly leave the area while shouting "wuzzint me!" |
This ^^^^^^. If it is the backup for security system, someone will have to access the system via the system code to reset the date, time, and other info that's ongoing as the system runs when you unplug the old battery. So if you maintain the power as you do the change over, you should be good to go for another five to seven years or more.
Marv Evans '69 911E |
Will take 24hours for unit to do a battery test then you can run your disarm code and it will reset.
It will not alarm when you unplug the battery, Batteries are 12 bucks at the supply house. |
If you have a battery fault, your battery backup is most likely not working anyways. Even if you disconnect power briefly, it will likely just see it as a temporary loss from the power line (like a brownout). I have done this quite a few times myself without problem. Unless you are securing the crown jewels, it is unlikely your system is spohisticated enough to care (intentionally)...to prevent false failure.
Still...be stealthy and be prepared to disavow knowledge if necessary as noted above. Last edited by fintstone; 06-13-2019 at 04:34 AM.. |
I'd hire a cute college intern just for that purpose
.WTF is wrong wif y'all? |
He is a local gov employee. Services performed by interns are likely limited to Lewinskis.
Batteries typically last 3 to five years then fail the alarm panel load test. I have dealt with hundreds of these honeywell panels and have only seen a couple with a bad charging circuit, in fact they are some of the most reliable electronics I have worked with.
If there is a problem....
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Who, What, When, Where, Why and How. |
Our household alarm has the battery backup as well. The panel will send me an alert that the battery is NFG, and I go get a new one. As soon as I disconnect it the "tamper alert" goes off, and I get a text and email, connect the new one, and another tamper alert, one more text and email, and I am done.
If you know the phone number for the monitoring company, call them first. Tell them you are going to replace the battery, and they can put it in a mode that is proper for replacement of the battery. Then tell them all is fine, and they will put it back to normal mode.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Gon fix it with me hammer
just pull the old battery on a friday afternoon when nobody is watching and vacate the premises..
they'll think the old battery just dropped voltage causing the alarm and somebody will replace it for ya
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Vaccinated and Boosted
this
2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space.... |
