dlockhart's Avatar
Originally Posted by gary1101 View Post
I have a Joes Pro 0-60PSI with hold valve. Very rugged. $50
I have a Joe's pyrometer for tire temps, and it was one of the tools that told us something was up with my fancy longacre gage. And the pyrometer double checked with the tire guys stuff.
Old 06-21-2019, 11:21 PM
wdfifteen's Avatar
Forget how it's spelled..but "bourdon tube" is the key. Yes, the more expensive dial gauges have them.
I have an Accutire bourdon tube dial gauge that I dropped. After that it read 2 psi when the pressure was 0. I opened it up and saw that the linkage between the bourdon tube and the dial needle appeared to be designed to be adjusted by bending a link. I adjusted it to read 0 at 0 and "calibrated" it by comparing it to a couple of other gauges. All were in agreement within about 1 psi. (Edited from previous post.)
https://www.consumerreports.org/cro/tire-pressure-gauges/buying-guide/index.htm
Old 06-22-2019, 01:05 AM
wdfifteen's Avatar
Originally Posted by afterburn 549 View Post
with in 10% is OK for your Schwinn or a model T
Typo - it was supposed to read 1 psi.
Old 06-22-2019, 02:46 AM
Ah. Rubbin's racin'. And racin' guys spend I would hope more than $70 on a tire gauge. It seems to me if you're going for tenths of a pound, then you are limiting yourself right off the bat to digital pressure gauges that have been tested. I mean it would seem logical to not reach for the old school free O'Reily's stick tire gauge and then be disappointed/ shocked.
Old 06-22-2019, 04:31 AM
Model Citizen
herr_oberst's Avatar
Just tested 3 of mine. I was not pleased with the results, but like many here have said, a man with more than one is never sure....
Old 06-22-2019, 10:16 AM
pwd72s's Avatar
Maybe I should buy another, so I can become confused?
Old 06-22-2019, 10:27 AM
I hope that if you've got 3 or more, that you have a majority that agree, ie, 2:1 or something like that. Then you at least stand a better chance of the 2 being right or closer to right.
Old 06-22-2019, 11:44 AM
Model Citizen
Nope, hence my disappointment, and 2 of the instruments are fairly expensive so I was expecting that they would be within a small percentage.
Old 06-22-2019, 12:05 PM
canna change law physics
red-beard's Avatar
Originally Posted by 1990C4S View Post
It is very unlikely that any measuring device you own is calibrated properly.
A cheap tire gauge? Nope.
An expensive tire gauge? Maybe. But not if it's old.
A sweep style meter? No.
Torque wrench? No.
Vernier? Probably okay.
Micrometer? Likely okay.
Ohmmeter? Likely no.
You should not be surprised.
Hence my issues with inflate-gate. They used an uncalibrated car type electric pump in a heated bathroom.
James
Red-beard for President, 2020
Old 06-22-2019, 12:51 PM
Air Medal or two
afterburn 549's Avatar
To reiterate,-
I was quite shocked and surprised as my old stand-by which was over 30 bucks back in the day and the other five gauges could find no agreement.
None.
It may, in fact, be right..but compared to what when I get the new gauge?
Will I now have seven gauges that have dysentery derivative dysfunctional psychopathic skill set?
(sort of like those that came up here from the bowls to add their two cents of drool)
There seems to be just no way of calibrating without a 5000.00 dollar machine.
Something so simple sometimes just is not.
If I could find three or four that read close to the same perhaps they would be right...but that is just betting on an average and not a sure thing.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 06-22-2019, 01:13 PM
True. That's usually good enough for me, but then I've apparently been lucky enough to get several that seemed pretty close.
Yeah, it certainly doesn't seem like an easy thing to fix if you want to get something calibrated.
Did you change your avatar? It seems different to me.
Old 06-22-2019, 02:08 PM
Originally Posted by peteremsley View Post
Hypothetically speaking, if you're traveling from NY to CA, would you lower the pressures on the left side to compensate for the sun?
silly I know, but a few laps on a track can change pressure by quite a few lbs... is the actual number that is critical?
I think the sun makes very, very little difference. Most of the heat in the tires comes from the deformation of the tire as it rolls down the road. Assuming you're going in a straight line on a good road with a relatively symmetric load side to side on the tires, they'll gain pressure pretty equally.
Old 06-22-2019, 03:44 PM
Bland
unclebilly's Avatar
Gauge accuracy is usually 2-3% of full scale. A 100psi gauge would have 2-3 psi of error.
This was fun for me in my previous life. I invented a oilfield completion system that opened based on pressure down hole. Here are the variables... the accuracy of the gauge on the pressure truck they use to open these, the density of the fluid in the wellbore (is it fresh water, brine, KCl water, etc).
Regardless, this system has 30% market share in North America and even higher in Russia and other parts of the world...
Old 06-22-2019, 04:53 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
TFSTTTT, right?
Exactly, ya' big ol' spanner!!!
Old 06-22-2019, 04:55 PM
Don't forget elevation changes. A curve like Turn 8, 8A and 9 at Laguna Seca can cause your tires to change psi and hence throw you off the gawdarn track!!
Old 06-22-2019, 05:35 PM
wdfifteen's Avatar
Where would one get a pressure gauge calibrated? When I worked in the lab our load cells and torque wrenched were sent out to calibration every few months and before and after every big test program, but we never used air pressure gauges.
Old 06-22-2019, 10:30 PM
dlockhart's Avatar
Tire vendors at the track often have one set up for teams to use. In everyday life, I have no idea.
"The primary contribution of government to this world is to elicit, entrench, enable, and finally to codify the most destructive aspects of the human personality."
Jeffrey Tucker
Old 06-22-2019, 11:45 PM
Tire Rack also sells the Intercomp digital tire gauge that is supposedly calibrated and tested. Maybe Intercomp would test and re-calibrate it's gauges if they're sent back in?
Old 06-23-2019, 01:19 AM
Air Medal or two
To sum it all up-compared the new to the old-I threw 4 away.
It is not scientific-law of averages.
I now have three that read the same.
Old 07-06-2019, 07:34 PM
