Here's what I found at lunch today. In the custom settings menu there is an Autofocus option. Selecting that gets a more selections and selecting AF activation gives you two choices, AF-ON only and Shutter/AF-ON
Choosing Shutter/AF-ON gets autofocus to work. It was on AF-ON only. I'm sorry I haven't been more present on this thread, continuous training of new assistant and getting way too much work done has me a little overwhelmed. I greatly appreciate all the help. Honestly, I would pay someone good money for an in person lesson. Have to get the 18-140 lens next. and so much to learn.
Tru6 Restoration & Design |
This new camera will expand the quality of social media and other posting, maybe advertising, so it's money well spent. I've been doing plating for 4.5 years now, the company was originally founded on plating. Great idea for a ruler to line up studs! I used to do artistic shots but the pics like the below but pictures are used for: knowing who's parts is whose, did anything get lost in preparation or plating (Have plated well over 50,000 pieces in 4 years and only lost 2 small nuts so far), for billing (count pieces) and for customer before and after (everyone gets their own dropbox folder). So clearly laid out parts is critical for fast and efficient billing since we bill by the piece. ![]()
Tru6 Restoration & Design Last edited by Shaun @ Tru6; 02-03-2020 at 03:41 PM.. |
AutoBahned
if no tripod then add light - lots of it
another trick is to use a background not too dark or light - close to the shade of the parts - e.g. set them on burlap instead of a white cloth & see how you like that you can also put them on a sheet of glass, with the burlap a foot or so below the glass - you can make them appear to float in space good luck & have fun |
Lighting is a HUGE challenge. Walls are very light grey with a hint of blue. Overhead fluorescent lights. Huge windows behind my back, 8 feet from the layout table.
Layout table is an old huge silkscreen oven base about 15 feet long with blue cloth cubicle dividers laid on it. That's for laying out somewhat clean parts. Greasy, off the car parts get laid down paper. Finished parts are laid down on light tan fleece as in the 914-6 suspension refresh pic. I am always adjusting color in Preview. Can't wait to see how the camera works with the new lens with this lighting, both fluorescent and natural. No lights, end of day, natural light streaming in only. ![]() ![]() ![]() ![]()
https://www.adorama.com/sa531257n.html?CategoryID=248030
Gray tint seamless paper. Neutral color, use as guide for white balance when editing. |
AutoBahned
^ yep
I usually use a brown (which might go well with the plating) you can put some LED lights at 45 deg & turn overheads off |
Thanks Dean. Paper may work better than the fleece. Or paper on the wall? I like the soft fleece.
I'm going to a local camera store tomorrow, they have a used 18-140 that I hope will work for me.
If you use the paper you can set up a rack behind the table so the paper hangs. You roll it out over the table and it becomes "seamless" with a gradual transition from flat on the table to vertical to the roll. When it gets dirty, cut it off and roll out a fresh piece.
I don't know how big of space you're covering with components, but I just set up my full frame DSLR on my tripod, pointing straight down, with the legs spread to the 2nd locking point to get the legs out of the frame and put some measuring tapes underneath. I had a clear 28in x 16in rectangle of floor space at a 48mm on a 24-120mm lens. You'd need a 35mm lens on the D7200 to get the same field of vision. You could then zoom as much as you wanted and reposition the tripod for detailed shots of individual pieces on a set up you could repeat over and over again. |
Not sure where you're going, but Hunt's in Cambridge should treat you OK and point you in the right direction.
These LED light panels work really well on cheap light stands. A couple of these would likely be pretty helpful in your set up. https://www.amazon.com/gp/product/B004TJ6JH6/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B00K69A0QY/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 |
Yes, Hunts Dean. Hunts did not call today. I'll call them on my way to a wake.
Fun with the camera today. ![]()
New lens. I can finally start to learn how to use the camera. They gave me a quick tutorial last night at the camera shop and as Scott has directed wants me to use manual. I'm doing a 1-3 hour lesson as well.
AutoBahned
He wants you to use Manual so yo'll be "forced" to learn what everything does.
You might be told to take photos of an egg - lots of different looks. Do it. Classic teaching method. |
You really need to use manual settings for the type of work you are doing. You'll probably need to be setting the aperture at the highest f- setting the lens will give you to get enough depth of field. You'll also want to keep the ISO number under 350. Given your time constraints you should tell him you bought the camera for a specific purpose and ask him to emphasize what you need to know to do the kind of work you need to do.
. Last edited by wdfifteen; 02-07-2020 at 12:21 PM.. |
Completely screwing around. So glad I got the 60mm lens. I have a lot of learning to do. And need to get some dedicated microfiber cloths. And lights.
Without doubt I will use this camera only for finished work and the Canon for incoming. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Takes good low light pictures too.
AutoBahned
is the Canon easier to use? easier to xfer images to the computer?
AutoBahned
you are getting some big specular reflections on the polished metal
to make it look nicer (and more slable?) try this: https://www.prophotostudio.net/2018/05/28/photograph-shiny-metal-objects/ |
![]() A little file manipulation shows a lot more detail.
Scott '78 SC mit Sportomatic - Sold |
AutoBahned
Don't tease - tell him how you did it
