Fleabit peanut monkey
However, I am stripping down this "one-off" '65 International Harvester D1300 to the nub with 80 grit. It's killing me.
1981 911SC Targa |
Brew Master
I could plumb my compressor setup to your tank and it would do the same thing only it would take less time to fill the tank once you stopped using air. I have about what a decent compressor/tank system costs in just my compressor and motor. My setup will last longer because it creates its CFM at a lower RPM so it runs cooler. I drove to Eaton and bought my setup about 12-15 years ago.
Nick Last edited by cabmandone; 02-20-2020 at 05:31 PM.. |
I have an Ingersoll-Rand that I got many years ago. It keeps up with my impact wrench just fine, and it is really handy to air up tires.
It is a bit noisy, but not horrible. The impact wrench itself is noisy and I wear hearing protection when using it. I have looked at the battery powered ones, and may ask for one when my wife asks what Christmas or birthday present I want. I love my battery powered drill-driver. I use it often and the corded ones are in the back of the drawer and have not been used in years. The one pain in the butt with cordless is battery life. It seems every time I have a big project and need my cordless hammer drill to do it's job, the batteries are dying and pitiful, and replacement batteries are often more expensive than the entire new unit. And there is no standard at all, so I end up with a different style of charger. I have three chargers now for the different tools.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
It is my understanding that high psi is needed for tools that need torque. Larger tanks are needed for tools that need high volume of air or constant use (i.e., paint sprayers). I've never run out of air; I have mostly used it for nail guns and filling tires. This one:
As much as I love the new cordless impacts, they are just huge! . My right arm is starting to look like Popeye's after lugging around my new Milwaukee Fuel.
I still love my old faithful IR 2135 air impact . It is my go to for transmission, suspension, and motor work . The cordless is great for wheels, and simple fasteners where you have a lot of room . And , I will add, The Milwaukee lists something like 1400 ft lbs of torque, but just this week, my air impact , that is supposedly only 800 ft lbs. knocked out a bolt that the Milwaukee would not budge .
No left turn un stoned |
Brew Master
Just removed and reinstalled a final drive on a mini excavator... all with my dewalt battery powered impact. I'm not talking about clean bolts. This thing is a 2008 that showed no signs of having the sprocket removed from the final drive. I'm EXTREMELY impressed.
Nick |
Evil Genius
show me one cordless tool that can blow compressed air.........
signed: 80 gallon 2 stage 175 psi
Life is a big ocean to swim in. Wag more, bark less.
Different strokes for different folks.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Brew Master
![]() Now show me an air tool that can run without compressor! I have two buildings that I store equipment in. If I wanted to work on a machine I would have to bring it over to the building that had the compressor or string an air line over to the other building from the building with the compressor. Now I just grab my battery powered impact and walk into the other building.
Nick |
I would add that you should look for a piston pump. There are some diaphragm pumps out there with good pressure specs but they typically lack CFM capacity. Just asking - do you already have an air impact and an air compressor that isn't strong enough? If so, I recommend sticking with the AC you have and getting a battery powered impact. I have both and I haven't used the air gun since I bought the battery powered one.
. Last edited by wdfifteen; 02-22-2020 at 12:54 PM.. |
This reminded me - DON'T GET A CHEAP COMPRESSOR!! This Harbor Freight POS could have killed me.
I May Have Dodged a Bullet Here
Would be perfect for OP. 200 vs 140psi when needed for short bursts would be handy to have.
"Big air" tools used often should have 15 CFM at their disposal. That's industrial sized and gets into money. I like Cab's second tank idea for my needs.
1981 911SC Targa |
Get a variety of impact wrenches. There are the "slow" wrenches in 3/8" drive for repetitive bolts. They won't rip out the threads of say aluminum blocks, for example.
Then there are 1/2" drive wrenches for everything from a 12mm to 19 mm impact socket application. I assume this is what you are planning. My Ingersoll Rand impact wrench is invaluable here, but I usually go for the Hazet socket and ratchet drive or box end wrenches. The impacts are used mostly for really stubborn stuff like rusty tractor or trailer bolts, in which case I usually go for the electric Makita 1" drive impact socket wrench. Why electric drive 1"? Because this thing produces WAY more torque than an air driven impact wrench. I also would recommend a oil bath compressor, not oil-less. No way would I run an oil less with an impact wrench. You'd burn it up in one afternoon. |
Pal has an electric 1" for removing his GT3 Cup car center hubs. To install he has an almost five foot long torque wrench.
1981 911SC Targa |
Someone said to me once, what do you need an air compressor for. Everyday Im in the garage I use compressed air for a multitude of things. Cleaning parts, works great for blowing the crap out of my pickup bed as well as the cab, it will do in a pinch rather than a vacuum job and much quicker. my garage floor is debris free. I have all the tools and use all of them, mostly the die grinder with a wire wheel. indispensable. I have a vertical tank wired for 220 and a 80 gallon tank. Had it for over twenty years. If it failed tomorrow I would replace it the same day.
It was righteous.
1981 911SC Targa |
The best air compressors tend to be the high end ones that dentists use. Trust me, they are bad-ass, super quiet, and will run forever. They ALL use oil bath lubrication.
gduke2010
I can explain my shop setup a little bit. The compressor is bolted to the floor, with a flexible hose leading to a pressure regulator and pre-filter on the wall that also is an air oil separator. There are in-wall and overhead hard lines, and a swivel with quick disconnect at the work bench. Drops have 90 degree ball valve "blow out" to remove accumulated condensation. Over the barn area, I have a hose reel, probably around 30' or so that can reach equipment. If painting, then I have a final filter and dryer just upstream of the painting rig. I haven't used it for automotive painting. I have a painting area for wood posts, slats, signs, etc (primer and outdoor latex paint and water bases sealer). It works ok, but for really stuck bolts, I have to use the "blue wrench" and biggie electric torque wrench and 1" breaker bar.
