AutoBahned
RWebb's Avatar
"Offset" Wrenches ??
I am trying to figure out what problem these Hazet wrenches solve, that regular closed ends don't...
Old 06-04-2020, 03:04 PM
Dunno, but they look cool.
Old 06-04-2020, 03:14 PM
Top left bell housing to engine nut on a 1963 Dodge Dart with a slant six and power brakes.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 06-04-2020, 03:19 PM
Hangover wrenches
Old 06-04-2020, 03:58 PM
wdfifteen's Avatar
Been there. It's not a 25mm bolt head.
Old 06-04-2020, 04:33 PM
Bill Douglas's Avatar
Yep, like most things, it's all about looks.
Old 06-04-2020, 04:36 PM
MBAtarga's Avatar
Maybe used on bolts in the first situation below - where the hole is too near the edge?
Mark
'83 SC Targa - since 5/5/2001
Old 06-04-2020, 04:57 PM
Just thinking out loud
mattdavis11's Avatar
Anything that has a distributor in the back. 350, 318 are two that had really long runs where those wrenches would be useful.
91 FJ80
84 Ram Charger (now gone)
Old 06-04-2020, 05:03 PM
wdfifteen's Avatar
Starter wrenches and distributor wrenches have a more serious offset. I can see where these wrenches would be an interesting alternative to straight box end wrenches, or a good helper in those places where a six point box end is so tight you can't move enough to get another bite. Just whip this baby on it an get that 1/16th of a turn you need.
Old 06-04-2020, 05:11 PM
Rear nut on 356 single barrel carbs...
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s
Old 06-04-2020, 09:41 PM
Still Doin Time
asphaltgambler's Avatar
You'd be surprised - possibly the difference in R&R'ing the nut or bolt quickly -or- spending half the day finding a work-around. There are many various types / styles of offset wrenches, some ratcheting. some where the offset is greater or more angled then 'average'.
I have a crazy looking offset, angled, dropped, box-end wrench designed for John Deere in-line diesels to remove the starter inside bolt. I bought it when I was in High school working part-time for the local JD dealer. I've had it ever since. I cannot tell you how many other times that I've needed that wrench to successfully remove fasteners.
Old 06-05-2020, 08:08 AM
vash's Avatar
maybe if there is a fastener near a obstacle..it allows more clearance for your handhold?
poof! gone
Old 06-05-2020, 08:46 AM
The good thing, though, is that once they get that big, standard and metric pretty much interchange. I think by about the time you're at a 17-19mm or an 11/16"-3/4".
Jeff
'72 911T 3.0 MFI
Old 06-05-2020, 09:01 AM
Counterclockwise?
You don't need an offset wrench until you need one.
Rod
1986 Carrera
2001 996TT
Old 06-05-2020, 09:06 AM
I always thought of offset wrenches as like this type.
I have just one of those, and I use it for the brake pressure switches that make the tail lights come on for my 911. That style of wrench makes it a lot easier to replace them.
As far as the wrench in the OP, I would say it gives a little bit more torque for the user if the nut is slightly off center. Not much, but a little more lever action.
Old 06-05-2020, 10:16 AM
....but don't have one .
Old 06-05-2020, 11:21 AM
Banned
I call those "gearbox" wrenches.
Corresponding set is open ended and short
Old 06-05-2020, 11:29 AM
Jon B.
Vista, CA
Old 06-05-2020, 11:50 AM
Banned
Only with the automatic.
Old 06-05-2020, 11:57 AM
Originally Posted by Jon B View Post
Yep. I made one of those for my 56.
Old 06-05-2020, 12:49 PM
