Removing Rubber Trim
My son is trying to remove the decorative door rubber trim from a 87 RX7. He got it off and the rubber is good. Now he is trying to get the tape adhesive strips and the goops of rubber glue someone used at some point to reinstall. Any suggestions on getting this stuff off?
To put back on, do people just use two sided tape? Thanks in advance. |
Did you get the memo?
Scrape off the worst of it, then use the solvent based Goof Off or a similar remover type product for the residue. Heat sometimes helps soften things up. If these are weather strips they have special glue for that, I think made by 3M. Just mask any surrounding painted surfaces and use a lot of clamps to keep everything in place.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
1996 FJ80. |
I use 3M adhesive remover. If it's a hard, dried glue, I'll sometimes soften it up with a citrus-based paint remover like Citristrip. Note that I'm careful to not get any stripper on the paint, just the glue.
As for what to put it back with, it depends on the trim. In some cases a two-sided tape is OK, other times an adhesive is good.... hard to say without knowing more about the shape of that particular trim piece. 3M makes a bunch of both. JR Last edited by javadog; 07-20-2020 at 07:51 AM.. |
Keep talking, Im gonna put you in the trunk. |
You do not have permissi
Heat gun with a wood/plastic scraper?
Meanwhile other things are still happening. |
Still Doin Time
3M makes the Magic wheel above. It's the shizzle
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Does that mean it is good or "crappy" as in shi......?
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I bought an eraser wheel years ago at a NAPA store and they work well . Old pinstriping glue residue came right off . It works by friction/heat of it spinning on the surface .
