You do not have permissi
john70t's Avatar
What color to paint cast iron NG pipe?
I'm getting around to cleaning up the basement and wanted to paint the pipe, which has slight surface rust.
Some of it is currently painted green by the previous owner.
Some is spotty black.
Most is unpainted.
I'm thinking black, but notice the flex lines are sold in yellow and industrial pipe is also yellow.
Old 07-21-2020, 07:11 AM
Brew Master
cabmandone's Avatar
Black paint would be fine since gas line is referred to as "black pipe" AFAIK, there's nothing that says you can't paint it whatever color you want. I've been in places where it was painted to match the wall color inside as well as outside the home.
Nick
Old 07-21-2020, 07:14 AM
Arizona_928's Avatar
carc 383 green if you want to spend some cash
dolor et pavor
Copyright
Old 07-21-2020, 07:19 AM
UnRegistered User
billybek's Avatar
Yellow is the colour nat gas black iron pipe is painted in Canada on commercial applications.
I think you are fine choosing any colour but you may have to degrease the outside to get paint to stick well.
Bill K.
Old 07-21-2020, 07:24 AM
LWJ LWJ is online now
I painted with coal tar I believe. The intention was to seal for rust. Did the job.
john70t's Avatar
I spayed some sections with rust converter primer.
Now airing out the house and waiting for it to dry.
Is Rustoleum enamel oil okay? or will it damage the pipe dope?
Old 07-21-2020, 08:15 AM
wdfifteen's Avatar
Take it all down and have it powder coated.
Old 07-21-2020, 08:33 AM
john70t's Avatar
lol.
Might be able to do that in place. Just need a few more heaters.
Old 07-21-2020, 08:57 AM
Bland
unclebilly's Avatar
Grey. Utility lines like this are grey.
Old 07-21-2020, 09:00 AM
Agree. Mine are yellow underground, and about 6" above ground. All the exterior black pipe is painted grey,
Old 07-21-2020, 09:33 AM
vash's Avatar
paint them the same color as the basement walls.
poof! gone
Old 07-21-2020, 09:34 AM
And we want you to pin-strip them all in a contrasting color!
No flame paint jobs however.
Old 07-21-2020, 10:38 AM
Eric Coffey's Avatar
Petrol Blue, or maybe Meteor Gray...use Glasurit of course.
Old 07-21-2020, 11:12 AM
Zeke's Avatar
Black or as Vash says.
Old 07-21-2020, 12:23 PM
Brew Master
cabmandone's Avatar
Won't hurt the pipe dope. You'll probably have a hard time getting paint to stick to the stuff though.
Nick
Old 07-21-2020, 12:34 PM
john70t's Avatar
Done. Looks good. No flames but decals are later. One thing off the list.
Thx for the replies.
Old 07-21-2020, 01:38 PM
MBAtarga's Avatar
Paint them baby poo yellow - to match the fence!
Mark
'83 SC Targa - since 5/5/2001
Old 07-21-2020, 01:49 PM
canna change law physics
red-beard's Avatar
Yellow is the "standard" color. But most just paint it black around here with a brush on Rustoleum.
James
Red-beard for President, 2020
Old 07-21-2020, 01:51 PM
john70t's Avatar
Shiny pipes. I also beefed up the hangers but it needs a little more.
The copper pound-in-loop type hangers can be tightened and tweaked by widening the loop, but that only applies a very small amount of pressure upwards.
(support is dependent on the copper wire not bending..which it definitely will.)
Perhaps that is a good thing.
Wood floors bounce and sag and shift over time. Pipe is solid.
I installed sections of cut up rubber bicycle tire between pipe and hanger.
Be sure to add a bit of flex space on both top and bottom when supporting pipe. Don't tighten it down too much.
Painted the walls with Killz. I have a sump and it's a dry basement.
Here is a glimpse of the dark pastel green from before.
Old 07-22-2020, 01:49 PM
Brew Master
cabmandone's Avatar
My whole basement was the same nasty green.
Nick
Old 07-22-2020, 02:02 PM
