looks identical to the bolts that came with a toilet wax ring I just installed. You could probably find these bolts at a hardware plumbing section
Old 07-31-2020, 11:22 AM
FPB111's Avatar
Trailex also uses them to hold most of their aluminum trailers together. Drill a hole in your anvil and hammer a hex bolt head flat then file/grind to fit.
Also
https://www.rockler.com/t-slot-bolts-pack-of-five-1-4-20-thread?country=US&sid=V91040&promo=shopping&utm_source=google&utm_medium=cpc&utm_term=&utm_content=pla&utm_campaign=PL&tid=pla&gclid=Cj0KCQjwgo_5BRDuARIsADDEntSo-BjBVN3dzt6yPHelx48C3sl6QhHk6XwnOfodQRPO-QIYilrM05EaAks_EALw_wcB
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 07-31-2020, 02:23 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by 1990C4S View Post
Those look like resistance weld studs to me, they should maybe have be projection welded into the door about 100 years ago....
There are absolutely weld marks where the original weld studs were positioned.
However, the only stainless acorn nuts were 1/4-20 at Lowes, so brass toilet bolts for the win.
1981 911SC Targa
Old 09-02-2020, 10:16 AM
New, I hope
Old 09-02-2020, 10:32 AM
I love me some home depot engineering.
07 Exige S
Old 09-02-2020, 11:10 AM
Dad's old '64 Travelall had mirrors a lot like that on it.
Had three gas tanks @60 gals total, split rims, it was a 1200 series.
They don't make them like that any more.
Scott
'78 SC mit Sportomatic - Sold
Old 09-02-2020, 04:40 PM
notmytarga's Avatar
Beat me to it, by a month - toilet bolts is what I thought as well.
Those non-wax rings are great. Reusable and a more secure seal. The void in the base of the toilet makes a good hidey hole. These rings make it simpler to use it.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 09-02-2020, 05:56 PM
Hell Belcho
Nostril Cheese's Avatar
T bolt or Trim bolt.
Old 09-02-2020, 06:05 PM
