A Man of Wealth and Taste
I am sorry to have to inform that my Salvatore joined the union and no longer worked right after 12 years of daily use. The options were to fix or replace. To replace that machine is now 2800 and is a custom order, hand built in America machine (my name is inside that machine for christ sake), or find something else? Since it is all commercial grade components it really was a fix it solution. Problem was who to trust in LV or send it back to Salvatore. I tried a large restaurant equipment repair company and for 300 it still didn't work right..my distrust was justified.
So it went back to Salvatore where he had a backlog of repairs and was extremely busy building new machines. So it sat for 5 months. They called last week with an estimate.there goes most of my Stimulus check..I said go ahead and by Saturday emailed it was ready. It has had a complete refurbishment of all the major moving parts..and is essentially a new machine again. the major problem unbeknownst to me was that RO water causes internal corrosion of the copper boiler and lines.. It is pure water which seeks content so it leaches the metal. The rest was preventative after long years of use. LV has very very hard water at 16 grains, where water using appliances have shortened life spans. So water filtration is a must to avoid scale buildup, just not RO. So now I have to use non RO bottled water like the recommended Crystal Geyser or go with a filtration system like BWT which in of itself has a much shorter cartridge lifespan because of the water hardness. Regardless of which way I go I do look forward to getting my Salvatore back in operation again for some good Joesph. After using up a small cheapo Krups, using a Bodum SS I finally wound up using a Corning Ware 6 cup peculator all found on the cheap at the Thrifts..
Copyright "Some Observer" |
canna change law physics
Internally, most of the Jura units are the same or very similar. They are differentiated by the features, looks and cost. 'Cause you know if you spend more it HAS to be better...
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
AutoBahned
I get the impression that Jura units overall are better built (from online research w/o seeing any of these things).
But I dunno about the outboard milk frother. That makes we want to go with a Gaggia. I haven't seen the Saeco brand listed at either of the big places that sell online. |
Band.
the major problem unbeknownst to me was that RO water causes internal corrosion of the copper boiler and lines.. It is pure water which seeks content so it leaches the metal. [/QUOTE]
I've replaced the copper heating elements in my simonelli twice for the reason you describe. you pull them out after a few years and although they still work, the metal is surprisingly soft and barely holds together.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Super Moderator
Well that’s interesting. We’ve been using RO water in ours for some time...
Honestly, RO water is not good for people. You need calcium.
Tabs, could you feed it bottled water from the supermarket. Those big cheap four or five gallon containers of natural spring water.
My Vibiemme needed a few new bits too so I've started looking after it better by doing proper two monthly deep cleans. Mind you, it's only eaten through one heater element in 15 years.
Band.
Gaggia / Saeco / Phillips are identical machines, rebadged.
The RO water issue is pretty well known in the coffee geek community. It also messes with water level sensors, which requires minerals to work. For that reason, folks that don't want to use tap often use the big carboys of spring water.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
[/QUOTE]It took 12 years for it to not run right. The Boiler on the Salvatore is copper as well as all the lines. There is no plastic in a Salvatore except for the Reservoir As you all can figure I am quite enamored of the Salvatore..when I bought it back in late 2003 Whole Lattte Love was a distributor for them...their description was glowing.. It is a custom order, hand-built machine from Buellton, CA. using all commercial parts..what is not to like. Back then who knew about RO water.. https://youtu.be/OAaNWrVlveU
The oxidation potential in RO or demineralized water is quite high. Typically, you use a resistant form of Stainless Steel.
The other issue: When the copper leaches, it goes "somewhere". That somewhere is in your coffee. And that copper ends up in YOU. https://en.wikipedia.org/wiki/Copper_toxicity Quote:
Now in 993 land ...
Not an expert on RO systems, but a good one should have a re-minerailzation step after you practically made DI water. I lived in a rental once that had a very elaborate RO system - the owners were esoteric folks that were afraid of traces of medication and what not in the drinking water. There was a 2 million year old piece of coral reef in the remineralization unit - calcium long built up before human presence.
I know all this because the unit broke and the service guy came by to fix it and educate me at the same time. After all that, I decided to just install a carbon filter in my house. G |
The last place I saw an RO home system, I do not remember seeing a re-mineralization system. I always wondered if the people with RO systems ended up with osteoporosis.
You don't use CA tap water in your espresso machines. Period.
We're stuck on the side of a volcano and have so much silicates in our water that you need a hammer to clean your glass shower doors. Ten years in now with RO and the Jura and the fridge are still OK. Interesting on re-mineralization though -- it's worth a look. I'd really rather the expensive toys not poop the bed...
'78SC, lots of other boring cars... |
Band.
Well, I don't know the chemistry; maybe there's some chemist types in here
Tabsys machine has a brass boiler with a copper heating element that directly contacts the water and sits in the water at all times, regardless of use. The thermoblock-style boilers (like In your Jura) are aluminum and stainless, and generally contact the water much less; they act more like an on-demand water heater in your home would. So maybe it's less of an issue. The copper heating element I replaced a few times in my simonelli sits directly in the water, all the time. So maybe it's a different story or chemical reaction.
AutoBahned
tap water here is great - the utility co. wins national awards for it, so I'm good there
a guy at Whole Lotta Latte Love or what ever that place is named told me the machines are very reliable as long as you clean them (and that lots of people don't) - what's the consensus on that reliability claim? |
