Hedge trimmer
I have had a Craftsman electric (extension cord/not battery) hedge trimmer for probably 30 years. It’s finally giving out and I need to replace it. I want to get a pole style trimmer this time and not sure what is the best kind to get. The battery powered stuff (blowers, string trimmers, etc.) scare me a little, maybe just because I’ve never had one. I’ve had good service from my Echo gas powered string trimmer. Wondering what your experience has been with pole trimmers and what you recommend. Thanks.
Not sure what kind of trimming you need to do. Mostly palms here and I use a Hackzall by Milwaulkee and a ladder. If they are too tall for my comfort threshold, I hire someone.
I also have a pole saw by Corona with a fiberglass handle that telescopes for the high up stuff that isn't too involved. For lower stuff I use an Echo double-sided gas powered 2 cycle hedge trimmer. I used it this morning at one of my accounts and it worked great, as it always does. I also use an Echo gas powered 2 cycle chain saw if need be. 16" bar. I've heard good things about the E-Go product line for cordless battery power tools but I've always been a Ryobi guy myself. But I don't use one so can't personally testify. Sorry. There's a lot of hand-held power tools out there. A LOT!
Old dog....new tricks..... Last edited by Baz; 04-26-2021 at 05:25 PM.. |
I've gone thru a lot of hedge trimmers over the years and I had very good success with E-Go battery operated. The battery lasts the full length of time needed to trim several large hedges. Unfortunately, the battery got stolen and I have yet to find a replacement.
For pole saw, I have a Sthil cordless. This was very expensive but works great. |
Buy Echo or Stihl, you will have a 20 year trimmer. I have these or very similar:
https://www.echo-usa.com/Products/Hedge-Trimmers/HC-155 https://www.echo-usa.com/Products/Hedge-Trimmers/SHC-2620S A little expensive up front, pay now or pay later. I got tired of replacing string trimmers, hedge trimmers and edgers every two years. These are great products, take care of them and they will last years. |
Old dog....new tricks..... |
I mostly just trim azaleas and other bushes but some are so wide I’m going to get a pole trimmer so the bushes don’t cut me up. The Echo pole hedge trimmer is about $500 and I don’t use it often enough to spend that much. Do the battery powered models work as good as the extension cord models? Does the E-Go model come as a pole trimmer?
Proud owner of a Stihl Hedge Trimmer as well as a Stihl Combi power head with Pole Trimmer, Weedeater, Brushcutter and Edger attachments. Fill them up with fuel/oil mixture, turn on the choke, pull the starting cord 2 or 3 times and it cranks right up. Coincidentally, I've been trimming shrubs all around the house the past week or so. Couple hours 3 different nights. We are hosting a party Friday evening and want the place to look presentable.
This picture is about 3 years old and the yard has changed some - but gives you an idea:
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? Last edited by MBAtarga; 04-26-2021 at 07:37 PM.. |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Still here
Craftsman fiberglass pole saw.
No power stuff, sawing branches above you must be done "gently" to put it mildy. ![]() Curiously, also have a Craftsman hedge trimmer I haven't used in years. |
I have a Stihl HS 56 C-E. It is very reliable and light in weight.
a.k.a. G-man
I thought this was a follow up from the cut my sack thread.
It's not. Carry on.
Сидеть, ложь, Переворачиваться |
Brew Master
I bought my dad a greenworks 40v extendable hedge trimmer. The battery is still good. The trimmer? Not so much. He snapped that thing like a twig somehow.
The few times I used it I really liked it. My dad is hard on stuff sometimes so who knows what happened to make it break at one of the pivot joints.
Nick |
Registered ConfUser
Don’t be afraid to try a battery powered trimmer. I took the plunge about 5 years ago. Don’t recall the brand but use it regularly and works great to this day. The battery holds a charge for a long time, recharges quickly and the trimmer does a great job.
I’m a convert.
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
I'll second the EGO battery hedge trimmer. The blades rattle more than my old, terribly hard to start Echo trimmer but it'll cut through at least a 1/2" branch if not a 3/4".
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
For a real pole (chain) saw the electric SunJoe brand on Amazon are excellent.
For trimmers, I have a Toro two-stroke that's really good.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
I guess this isn't another "cut my sack" thread then?
< edit > apparently, I'm very late to the party < /edit > Quote:
I've had good luck with the Ryobi "One" stuff from HD. 18v battery that is interchangeable with most of their stuff.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Counterclockwise?
I've been happy with my Stihl electric. I plug it in, trim the hedges, put it away with a little oil on the blades.
My concern with the battery is how long will it last. If it's 5 years and I trim twice a year I get 10 trims before needing a new battery.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
i'm old school. I used hedging shears, but I was torturing myself, so I took the entire vine hedge out. no more need
poof! gone |
Anyone gas powered tools for personal grooming? Industrial grade? Hehe
