Banned
Removing old chrome:
Any ideas appreciated. Long story short, I need to remove some old chrome that is in bad shape from a motorcycle part and then have it painted. I've been told that the only places with the vat of chemicals to do this are plating businesses, which are getting scarce and apparently can really name their price these days.
I was just quoted $150 minimum "shop charge" to dip this thing. That's a deal killer, I still need to have it professionally painted. I'm, going to talk to a body shop today, maybe they still have a bumper service(?) The part: ![]() ![]() ![]()
Possibly sandblast.
Muriatic acid/water mix |
Feelin' Solexy
I would recommend checking out powdercoat, I've seen some "chrome" powdercoat jobs that were pretty impressive... not as good as real chrome but pretty nice.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Check out Artistic Plating in Harbor City. They stripped off the chrome from one of my Nortons a few years back.
'72 Norton Commando, '47 Sunbeam S7 '14 Tacoma |
944 S2
Why remove the chrome? I would sand and prep for paint right over the chrome.
The Unsettler
If we are talking bumper hitches I know a chick.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Member
+1
Sand, prime and paint. The triumph parts all seem to like Rustoleum Engine Enamel. Been wondering how your project is progressing......... Engine back in and running??
Paul 91 964 C2 Targa sold (shipped back to the fatherland) 09 Cayman PDK 17 Titan 55 Sunbeam S7 Deluxe 70 Triumph Bonneville |
Just media blast it with aluminum oxide at 100 psi. The media will create a nice etched surface for the epoxy primer too.
Tru6 Restoration & Design |
They beat me to it already . I have sand blasted a few sets of older chrome truck wheels, and then painted them, and not only did they turn out great, have held up pretty well, even on my snow plow truck .
No left turn un stoned |
Banned
Thanks all! It did not really occur to me that I could just sand and paint over it. Or more specifically, that it would bond well. It also occurred to me while reading your responses that my buddy recently acquired a small media blast cabinet, time to try it out!
Banned
Make sure you use the correct media. Glass bead will probably remove the chrome but just dimple the surface. Some 180-220 sanding over that would work for paint surface prep but Al2O3 will give you the best surface ready for paint uniformly all over the part.
Where were you for my "Golf ball Through A Garden Hose" thread?
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
Banned
Done correctly, you want an etched surface for the epoxy primer to grab onto. Etched means more surface area for the primer to hold onto which means better adhesion. Fine grain aluminum oxide is the best choice for this job.
Kessel run in 12 parsecs!
Sand blast it smooth. Just rent a blaster and do it yourself. Its easy..
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Banned
So, I took the old spinning disc to it, just to see what the effect would be. I have to say that it looks good for painting and if my bike was more of a rat or a bobber, it looks kind of cool as-is. Should be a good surface for paint adhesion...opinions?
![]() ![]() ![]() It was a really coarse disc, maybe I should sand it with a lighter grit now? |
The thing is, and I think Denis knows this, is that there is likely some rust under the copper base plating. It should dome down to bare metal. A stiff wire wheel will get the stuff he can reach, but dipping or blasting will make sure.
There is a lot of debate about dipping things that are joined by spot welds, etc. It takes extraordinary effort to make sure the blind areas are neutralized. I knew of one restoration shop that refused to did anything but engine blocks and the like. So that bracket could be a problem if not done right. |
Banned
Couldn’t that spot weld just be touched up if necessary?
