A930Rocket's Avatar
Compression check thoughts…
I did a compression check on the 05 BMW 330ci today and wanted your thoughts.
1 and 6 look close, as does 2-5.
Old 09-06-2021, 10:20 AM
Those numbers look pretty good to me.
How many miles on the engine?
Scott
'78 SC mit Sportomatic - Sold
Old 09-06-2021, 10:35 AM
A930Rocket's Avatar
Originally Posted by scott douglas View Post
those numbers look pretty good to me.
178k
Old 09-06-2021, 10:39 AM
Then they look damn good to me.
What are you worried about?
Scott
Old 09-06-2021, 10:41 AM
A930Rocket's Avatar
With the ticking/tapping noise at part throttle over 2600 rpm, I’m just looking into the health of the engine.
I’m about to dig into replacing the lifters.
Old 09-06-2021, 10:58 AM
Still Doin Time
asphaltgambler's Avatar
If you did a top engine clean with a BMW approved cleaner, those numbers will move closer together.....
Old 09-06-2021, 01:45 PM
greglepore's Avatar
This
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 09-06-2021, 02:35 PM
A930Rocket's Avatar
That’ll have to wait until I reassemble it next weekend. I did run two quarts of ATF for a few mikes and some idling last weekend.
Edit: I probably should’ve gotten a new compression tester, as that one is at least 40 years old.
Old 09-06-2021, 03:09 PM
wdfifteen's Avatar
Those numbers at 178k? You’re showing off.
Old 09-06-2021, 06:05 PM
A930Rocket's Avatar
What is the BMW approved cleaner?
Old 09-06-2021, 06:28 PM
jyl jyl is online now
jyl's Avatar
I had a PPI on a BMW I-6 and noticed a similar pattern - cyl 1 and 6 similar and higher than cyl 2-5 which were consistent with each other.
Is that common with inline 6 engines or with BMW 6 cyl?
Old 09-07-2021, 02:20 AM
A930Rocket's Avatar
I wish I could post a gif or video of the chain ramp that the tensioner presses on. It has a wobble, instead of only side to side movement Am I thinking right?
Old 09-07-2021, 08:03 AM
Gon fix it with me hammer
svandamme's Avatar
real health : get leakdown test.
compression test looks good but only tells a basic story
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-07-2021, 11:35 AM
