Dewalt pilot point drill bits are da bomb!
If you have any drilling to do coming up . These are your huckelbery.
I just had to drill out 5 studs and lugs on a pos dodge caliber. They did not just spit out chips, but huge curly que's just flyng the whole time. I got through all 5 studs and lugs in under an hour (usually a couple hour job at best ) and with only one bit . I have a bunch of high dollar drill bits bought from snap on, and others that I source from Winzer, and they don't even begin to touch the dewalt bits. There is also another spiral tipped drill that is now available to the public. I demo'd them, and they were pretty awesome, but a little bit harder to get and more $
No left turn un stoned |
Perfect timing. I have some small rivets I need to drill out and I was worried about the project on my DD spiraling out of control if I ended up with a bunch of broken bits.
Still Doin Time
link please.....
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Brew Master
Fred,
I've seen those but always wondered what you use to sharpen them when they get dull.
Nick |
These?
https://www.dewalt.com/products/accessories/metal-and-wood-drill-bits/metal-drill-bits/16-pc-pilot-point-drill-bit-set/dw1956 Seems like a cobalt center drill would be just as good... https://www.amazon.com/HHIP-5000-3011-Cobalt-Degree-No-1-No-5/dp/B06Y5NM9ZY/ref=sr_1_4?crid=29O78G6B8FJK8&dchild=1&keywords=center+drill+cobalt&qid=1634826815&sr=8-4
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." Last edited by 1990C4S; 10-21-2021 at 07:34 AM.. |
Fred, I am a big Mopar guy but I have to tell you when you say POS and Caliber you are being redundant!
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
As I was doing a clutch job and replacing the flywheel on my trusty 914 2.0 I go down to the flywheel. The Allen head bolts had two that were stripped, and needed to be drilled. I whipped out my trusty Sears bits I had for years and after 10 minutes it had a tiny dent in the bolt.
My 914 was my only car back then, so I borrowed my neighbors bike and rode to a nearby tool store. I bought some cobalt bits and was astonished when they ate into the bolts like it was made of wood. They made short work of the bolts, and I finished the clutch job. I threw out the old Sears set and started collection good drill bits.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
R&D guy
Location: the border between the states of inebriation & confusion
I had to replace some parts on the front clip of my daughter's car (someone backed into the car when it was parked) and drilling out a broken rusty bolt was required.
My existing drill bits (most of them good quality HSS) were a no-go for this task so I picked up a set of the DeWalt Cobalt drill bits: https://www.lowes.com/pd/DEWALT-14-Piece-Cobalt-Twist-Drill-Bit/50413714 These worked REALLY well for that job, and the centering feature was quite helpful, but I did notice two drawbacks with additional use: 1. If you drill a smaller "pilot hole" and try to go up gradually in size to enlarge the hole, the lack of a stand point angle on the flutes for centering is a problem. 2. Because of the unique point geometry, they can't be effectively sharpened by any means I have available, and I have a "Drill Doctor" sharpening tool as well as a standard-type bench grinder. Despite these drawbacks, I very highly recommend these for anyone needing to drill into or through hard metals. And remember: Cutting oil is your friend. |
A sharp drill bit is all that is required, bench grinder and a little practice.
87 930, |
Control Group
your credit card
She was the kindest person I ever met |
Brew Master
I've had really good luck with the drill doctor. I've done the bench grinder thing but the edge never seems to last as long as the drill doctor edge does.
Nick |
I see you
You guys ARE talking about actually drilling down the shaft of a rusted in bolt right? Not just drilling off the bolt head.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
With the pilot tip - I don't think these would be possibly sharped on the drill doctor (which I own) - nor on a bench grinder. You could sharpen the tip - but you can't get the edge sharpened below it.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
R&D guy
Sometimes drilling it large enough for a clearance hole and sometimes drilling for tapping and/or Helicoils. |
