Just another bribe for votes. This time farmers and the AG industry.
Brew Master
Nick |
Brew Master
That's all set through the motronic. I have an onboard wideband 02/AFR gauge. It's the only reason I know that there is a difference. The ethanol blend fuel tends to burn a bit leaner when I run it than pure gas. I've just never asked anyone why because I was afraid they'd think I was nuts or stupid.
Nick |
I want to say, maybe in the early 1980s there was a tech article in Road & Track about oxigenated fuel, and how the Fed EPA might mandate it's use in order to force vehicles to run lean. I was maybe 12 or so when I read it, so I didn't fully understand all of it, but I was aghast at the fact that they would mess with the fuel that you buy, making it less efficient.
And here we are today with the (literally) pisswater gasoline that will destroy your vehicle. |
Control Group
Again, nothing in this is correct, that is not why ethanol was added to fuel, no matter how many times you say so.
She was the kindest person I ever met |
OK, so your ECU or "Motronic" (Bosch L-Jetronic in other words) will take over and go into closed loop once the O2 sensor heats up. You'll notice that it will lean or richen the fuel mixuture until it gets to .99 to 1.01 Lambda. It does not allow your vehicle to run lean or rich. If your AFR is showing a lean mixture, then your fuel injection system is broken. I wrote a quite lengthy description of all this on Rennlist way back about 12 or 14 years ago. |
Yes it does
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Brew Master
Nick Last edited by cabmandone; 03-09-2022 at 05:21 PM.. |
Brew Master
It always runs on stored maps. With the 02 sensor or without.. it's running on stored fuel maps.
What I mean is, If I'm at WOT I'm running on the WOT fuel map that changes the AFR to around 12.9-13 At tip in I might go from 14's down into the mid 13 range At idle I'm set at around 14.2 but when I put pure gas in, for some reason that number drops into the range I've mentioned.
Nick Last edited by cabmandone; 03-09-2022 at 05:43 PM.. |
No, that is not what I am saying. How long does it take ?
Keep talking, Im gonna put you in the trunk. |
Brew Master
I didn't know Vettes were flex fuel vehicles! So if nothing else comes from this thread, at least I've learned that.
Nick |
Mine was not flexfuel. I put in bigger injectors and tuned the ecm myself.
Brew Master
Interesting. I guess I've never looked into what makes a flex fuel vehicle different from a non flex fuel vehicle.
Nick |
Not that much. My car was not a true flex vehicle. It was either premium gas or e85. I simply switched programs as needed. All one really needs is bigger injectors and a bigger fuel pump. I already had the big pump.
Functionista
Bosch Motronic is unable to run closed loop at WOT.
Oxygen sensor has no input, uses preset maps to fuel the engine. In stock form you will find that it’s a fairly rich AFR. I recall when oxygenated fuels first came out. Some dyno runs with sport bikes showed an increase in power. You could get disqualified in racing using pump gas vs high octane race gas if they were fuel testing that weekend.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Exactly right. At cold start up, and at WOT it runs pre-set maps. It also does not have short term fuel trim. That came later.
My F150 that was Flex Fuel would go from 17 MPG to 13 on Ethanol. Not cheaper in the long run at all
Patrick |
Gon fix it with me hammer
1 fossil fuel is stored carbon in the earth 2 dug or pumped up.. 3 burnt to release CO2 in the atmosphere ENDprogram 1Ethanol is grown on a field, absorbes CO2 2turned to ethanol 3burnt to release CO2 in the atmosphere 4 Go to 1 it's BS, but ok, that's the concept
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
