Brew Master
cabmandone's Avatar
Turns out it's because there's more oxygen in ethanol fuel! I know someone here touched on oxygenation of fuel but I didn't look into what they really meant.
"Another effect of the oxygen from ethanol is that ethanol blends tend to run "leaner" than pure gasoline because there is more oxygen available in the fuel-air mixture.
My car wouldn't change the airflow through the AFM because without the 02 sensor in the system, it has no idea it's getting more oxygen from the ethanol fuel. Since I'm not talking big swings in the AFR, I was never concerned. I just always wondered why I saw that difference when going from pure gas to ethanol.
Originally Posted by chapo View Post
My F150 that was Flex Fuel would go from 17 MPG to 13 on Ethanol. Not cheaper in the long run at all
That's huge! My F250 only drops about 2 mpg but it's a pig. I'd feel happy if it ever got 17 mpg.
Nick
Old 03-10-2022, 02:36 AM
Gon fix it with me hammer
svandamme's Avatar
I don't see how that at all adds up.
the Airflow through the AFM or MAF is a function of the throttle
the throttle is done by your foot, or the cruise control
Engine Management happens as a result of air flow through the AFM/MAF , not with airflow.
Throttle determines airflow
TPM + AFM/MAF + RPM determines Main injection output
O2/lambda sensors in the exhaust adjust secondary injection control
None of that controls airflow on the inlet.
if at all the engine gets more or less O2 in it's mixture will be picked up by the O2/Lambda measurements.
and then more fuel gets injected.. Obviously if that fuel itself contains O2, it will do more injection to overcome that
Since it's only a small percentage of the fuel that is Bio and contains extra O2.. it will overcome that surplus quite quickly.
To my knowledge no engine management system adjusts the throttle position on the E-throttle systems as a function of closed loop. Mixture Trimming happens on the injection. Ignition timing is secondary and for performance/knock.
If anybody were to try trimming both injection and throttle, it would be way to complicated to map. to many variables.
No ROI
Only throttle control I can imagine is basic idle control...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-10-2022, 03:11 AM
Brew Master
cabmandone's Avatar
I don't think it's as simple as "throttle controls the AFM". And again, my car gets no measurements. There is no 02 sensor in the system so the engine has no idea what's going on.
Something to keep in mind, I don't pay attention so much to throttle under load. When I'm saying my AFR is leaner, I'm talking under idle or cruise conditions. At WOT I'm in the 12.9 range
Nick
Old 03-10-2022, 03:16 AM
svandamme's Avatar
I'm not saying Throttle controls the AFM.. it controls the airflow
AFM simply detects that airflow.. in a way the AFM is a result of the throttle+temp+pressure. and Technically the throttle does control the result of that AFM, but it's indirect.
If you have no 02/lambda, then you have no closed loop
so whatever your engine does, is preprogrammed based on the inputs.
AFM
TPS
RPM
Knock
other
You said "my engine doesn't know it has extra O2 iun the ethanol, so it doesn't adjust the airflow"
I don't see how your statement can be true, eg that your engine mgmt somehow controls the airflow... That would be unique and groundbreaking.
Stijn Vandamme
Old 03-10-2022, 03:27 AM
Brew Master
cabmandone's Avatar
I probably should have been more clear about where I see the leaner AFR. If I take the car out and get it fully warmed up, my idle with pure gas will be in the 13.6 to 13.8 range. At cruising speed my AFR will typically be in the 13.8 to maybe 14 range with pure gas. When I fill up with a blended fuel I can see the difference in idle AFR as well as my AFR at cruise. I initially set my base idle mixture (running ethanol fuel) so it would be at 14 to 14.2.
Nick
Old 03-10-2022, 03:28 AM
Brew Master
cabmandone's Avatar
AFM
TPS
RPM
Knock
other
I follow what you're saying and I miswrote my first comment. The throttle butterfly controls air flow. I should have said it doesn't adjust the mixture rather than the airflow.
Nick
Old 03-10-2022, 03:35 AM
svandamme's Avatar
ok, but it's still just what you do with your foot.
at idle, all you can do is control the Idle bypass + idle rpm injection
And perhaps temp sensor so the darn thing understands it needs a bit more fuel in cold state.
AFM really doesn't do much at that point...it only becomes relevant when you move out of idle.
and what fuel you use, it's really not something you can control much , the rpm and airflow is too low and anything you measure becomes a statistical variation you can't even measure or fine tune the idle mixture by hand..
only thing it has to do at idle.. is run smooth enough and not stall
That's all that matters And I'm pretty sure if it runs smooth on bio ethanol, it will run smooth on regular fuel with high or low octane... or vice versa
Stijn Vandamme
Old 03-10-2022, 03:41 AM
Brew Master
cabmandone's Avatar
Like I said, the mention of the AFM and air flow was a mistake on my part. I should have said "mixture".
Not sure what you mean by I can't fine tune the idle mixture. (Forgive me if I'm misreading that. I'm only working on 4 hours of sleep) I can make the idle mixture rich or lean by adjusting the screw on the AFM.
Nick
Old 03-10-2022, 03:55 AM
svandamme's Avatar
That an engine in idle running state takes in very little air and takes very little fuel
And its very hard to control that idle running smooth by looking at an AFR output in the exhaust.
wether or not it runs smooth for the most part has to do wit h the character of the engine
at that point idle bypass sets the RPM with the air, and smoothness with a idle injection setting.
Sure you can look at AFR at that point.. but your ear is going to be the final judge if you like how it runs at idle or not. It's not a fine tune that anybody can measure with sensors.. either it runs smooth, or it doesn't.. no sensor needed to hear it surges or barks in the exhaust.
Stijn Vandamme
Old 03-10-2022, 04:04 AM
Brew Master
cabmandone's Avatar
Where did we get into smooth running or not? I didn't say the engine doesn't run smooth. I said it burns slightly leaner. You have to be ridiculously off on the mixture to hear a difference.
Nick
Old 03-10-2022, 04:10 AM
svandamme's Avatar
I'm saying, WHO CARES if it runs a smidgeon leaner at idle
the variation/error of measurement is to big in that operating state of the engine.
None of it matters
unless you are in some kind of lab.. that measurement can go one way or another based on any of the other variables of the day.. barometric pressure, ambient air temp, engine temp state, fuel temp
the fuel you put in
unless you can switch fuels at the flick of a switch and compare the AFR variation each time, on the fly, your measurement and comparison is pointless. It's within the tolerance of your measurement variation.
Stijn Vandamme
Old 03-10-2022, 04:11 AM
Brew Master
cabmandone's Avatar
Okay... you're flying off the rails now. Have a good day.
Nick
Old 03-10-2022, 04:17 AM
svandamme's Avatar
IF you want to get a decent comparison, you'de be better off with a car that has actual Lambda and trim.
then it's just a matter of driving 2 tanks of fuel worth.. let the ECU figure out what the engine does..
And connecting ODB2 reader, to check short and long term trim
if it's leaner or richer with a certain fuel, you'll see a change in trim state.
spot readings of AFR do nothing . especially not at Idle. Anybody who ever tuned MFI can tell you that.
Stijn Vandamme
svandamme's Avatar
I'm not flying off the rails, i'm explaining something but you don't care to listen because you made up your mind about it because you have a measurements that backs up your made up mind.
it's not scientific.
Stijn Vandamme
Old 03-10-2022, 04:20 AM
Brew Master
cabmandone's Avatar
It was an observation that I've made on several occasions. I'm sorry for triggering you. Calm down and move along.
Nick
svandamme's Avatar
Why do you think i'm not calm??
Stijn Vandamme
Old 03-10-2022, 04:22 AM
canna change law physics
red-beard's Avatar
Originally Posted by Superman View Post
I've never heard of ethanol as a strategy for reducing emissions. Ethanol is added to gas because it is a less expensive way to bump octane up.
We need to get Sammy to help here...
It had 2 functions
1. Oxygenator for non-attainment counties in the USA. edit - (To reduce CO "carbon-monoxide" in the exhaust)
2. Octane booster
MTBE had the same function and it was "closer" to gasoline in heating value and only required a 5% mix to do the same thing as ethanol.
Refiners could put in either, but MTBE was cheaper. California banned MTBE (in the 1990's?). Since it was mandated at the federal level, MTBE users were "protected" against lawsuits. The EPA pulled that exemption and everyone switched to ethanol.
Then 2005 occurred with the RFS. And the corn farmers rejoiced.- Edit - The RFS mandated the 10% ethanol blend everywhere. And the refiners rejoiced, since they didn't need to make summer/winter and attainment/non-attainment versions of the fuel. Just ONE version.
edit - At the price, E85 seems silly. If it were 30% cheaper than gasoline, sure. But E85 does have a very high octane rating. For flexfuel vehicles that can make use of high octane fuel with advanced timing changes, it can be a good thing for power, etc.
James
Red-beard for President, 2020
Old 03-10-2022, 06:09 AM
red-beard's Avatar
Originally Posted by rusnak View Post
Welllll....look I am not picking on you. But all an AFR meter does is measure the percentage oxygen in your fuel, and it extrapolates the fuel mixture calculation from that. It does not measure exhaust gasses such as CO or NOX.
OK, so your ECU or "Motronic" (Bosch L-Jetronic in other words) will take over and go into closed loop once the O2 sensor heats up. You'll notice that it will lean or richen the fuel mixuture until it gets to .99 to 1.01 Lambda. It does not allow your vehicle to run lean or rich. If your AFR is showing a lean mixture, then your fuel injection system is broken. I wrote a quite lengthy description of all this on Rennlist way back about 12 or 14 years ago.
An Air fuel ratio valve is used to adjust the ratio of fuel to air based on the change in the heating value of the fuel. Use a lower BTU content fuel and you want more fuel to air. All of our engines running on Landfill Gas use air fuel ratio valves because the BTU content of the landfill gas is not consistent.
James
Old 03-10-2022, 06:16 AM
Samny went AWOL along with a whole bunch of long timers in the past year or so ... hope he and the rest of them are doing OK and just avoiding PPOT.
Old 03-10-2022, 06:21 AM
red-beard's Avatar
I think he moved out of California and is swimming in a vault of gold, like Scrooge McDuck.
James
Old 03-10-2022, 06:23 AM
