Math question: diameter from a portion?
Hi,
I have a small wooden part with a curve to it and I want to replicate it on the lathe by turning a complete circle so trying to figure out how to take the measure of the slice to get the whole.
To make a simple comparison, if I had a slice from a pie and wanted to figure out the diameter of the pie from just the crust curve of one piece.
Hopefully the brain trust can steer me “straight”.
Thanks,
Rutager
Rutager West
Old 03-14-2022, 05:44 PM
I think this calculator gets you what you need:
https://www.omnicalculator.com/math/sector-area
1982 911 Targa, 3.0L ROW with Webers
Old 03-14-2022, 05:49 PM
Model Citizen
herr_oberst's Avatar
Like this?
Old 03-14-2022, 05:50 PM
I was about to say "I love banana cream pi"...but am afraid of where that might go.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-14-2022, 05:56 PM
John Rogers's Avatar
You can do it by math or get a large enough piece or craft paper and stick a pin to act as the center and rotate your piece around it and draw a line on the outside until you get a full circle. Then measure across the circle.
John
Like this?
Perfect- great explanation and easy to follow.
Thanks!
Rutager West
Old 03-14-2022, 06:07 PM
Thanks, I found that one, but my math skills aren’t good enough to figure out where to put all the numbers!
Rutager West
Old 03-14-2022, 06:09 PM
Mmmm... Cherry Pi
Almost Banned Once
sc_rufctr's Avatar
Happy Pi day
- Peter
Old 03-14-2022, 06:11 PM
Ha ok! There are links to definitions of each variable so that might get you close.
What about making a compass thats big enough to accomodate the wedge?
Old 03-14-2022, 06:13 PM
^^^ That's what she said.
98 Honda Prelude
22 Honda Civic SI
John
Hi John,
In this case, my piece doesn’t go to the center, but I bet I could run lines down each side and measure from the middle to get the empirical answer. Just tried it and apparently the diameter would be huge as the lines weren’t even close at two feet out! I may have to give up on the lathe idea.
Here’s the project- I got a bunch of hand plane bodies and I wanted to make a custom wood infill for one. The originals were Rosewood or anodized aluminum, so I do have a piece to use as a pattern, just thought it would be easier to turn a section, but my lathe won’t turn a huge diameter inboard and I’ve never tried outboard turning.
Rutager West
Old 03-14-2022, 06:16 PM
Apparently Byron left his camera at my place! Sorry about the blurry picture.
Rutager West
Old 03-14-2022, 06:17 PM
Banned
this is an easily googable problem.
Old 03-14-2022, 06:40 PM
The Unsettler
stomachmonkey's Avatar
Seems infinitely simpler to use one of the pieces to trace out a template then hand shape.
"I want my two dollars"
"Brandon Won"
Old 03-14-2022, 09:33 PM
Almost Banned Once
sc_rufctr's Avatar
Yes it is but...
- Peter
Old 03-15-2022, 12:44 AM
Yes, once I determined how huge the diameter was going to be, that’s the route I will take.
My initial thought was that since it had several facets and a compound curve that I could get a “perfect” shape if I turned it and could also make several at once and even out of different woods by doing segments on my round blank.
Rutager West
Old 03-15-2022, 04:01 AM
Senior Member
Superman's Avatar
Clever.
Mocha 1978 911SC. "Coco"
Old 03-15-2022, 07:41 AM
Takin' hard left turns
Amail's Avatar
You could rough-cut the shape, then attach it to a long pivoting arm and pass it over a router.
Old 03-15-2022, 07:45 AM
MBAtarga's Avatar
Rutager,
If I follow your issue - why don't you cut a jig to match that diameter and just use a router with a follower bit and/or bearing?
Edit - I didn't see Amail's comment which he posted after I had opened the tab a while ago.
Mark
'83 SC Targa - since 5/5/2001
Old 03-15-2022, 08:18 AM
