Removing a snapped and sunken bolt
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Registered ConfUser
I am hereby proclaiming that I will never find myself in need of such skill, so will dutifully avoid watching the video.
So, what are the odds I’ve just jinxed myself?
Mike “I wouldn’t want to live under the conditions a person could get used to”. -My paternal grandmother having immigrated to America shortly before WWll. |
Thanks for posting! I never thought of center drilling a bolt to use as a guide. Great info, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Parrothead member
Perfect timing.
I snapped a head bolt on one of my outboards last night..
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
That is neat, but I don't have a lathe to make a drilled out bolt to center the drill bit. I wonder if anyone sells a set of bolts that are drilled out for drilling a broken bolt. Of course I would need a set for SAE and Metric.
Or better yet, avoid breaking any bolts!
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
UnRegistered User
That is a great idea!
Thanks for posting the video.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Gon fix it with me hammer
if you use an axle grinder , you can get it removed pretty easy, especially in aluminium the grinder goes through it like butter, just a single cut along the lenght of the bolt usually does the trick
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
You dont need a lathe for that. A good drill press and a bit of centering will get you there just as well
What is he have so many broken bolts to begin with? lol
McMaster has a few vented bolts that would get you started. Screws https://www.mcmaster.com/Screws/vented-hex-head-screws |
Kantry Member
Just hit the broken bolt with a punch to start your bit. Takes seconds and works.
One size fits all. Best Les
Best Les My train of thought has been replaced by a bumper car. |
You do not have permissi
iff'n you want to get fancy, there is EDM https://forums.pelicanparts.com/search.php?searchid=23998599
Whacking the face of a bolt with a hammer, a little heat around it, turn in a hair and then out, impact, always helps.
Meanwhile other things are still happening. |
To bad none of these tools will remove my broken spark plug threaded section.
https://www.amazon.com/Lisle-65700-Broken-Remover-Engine/dp/B00SQ4FSN6/ref=asc_df_B00SQ4FSN6?tag=bingshoppinga-20&linkCode=df0&hvadid=80333123589171&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583932709120767&psc=1
Spring loaded center punch and left handed drill bits work fine from my experience anyway. Good video though, it's always nice to have options.
"A little nonsense now and then is relished by the wisest men." Wonka |
I have a couple sets of these, slicker than you know what
No left turn un stoned |
Pwd:
Wish it were that easy. Plug snapped at the threaded portion in my 2010 Cayman. These won’t work. |
Damn...so gotta pull the head? Ouch! $$$$.
That's cool!
