What causes the level in the toilet bowl to radically change?
You flush the toilet and after the water leaves the bowl, the bowl then fills back up until the surface of the water is maybe the size of a dinner plate.
The next day you flush the toilet and the water only fills the bottom neck of the toilet so that the surface area of the water is a tiny fraction of what it was. The tank on the back of the toilet seems to fill correctly. One thing did occur, the pressure switch in our well pump died and I replaced it. But it was replaced with the same pressure (40/60) and everything in the house seem to be working the same, except the toilet. THere's a second toilet in the house, and it's working fine, but it's got a pressure vessel in the tank while the one acting different uses a "kohler canister flush valve" similar to this
These work great...and are super easy to install.
https://www.amazon.com/dp/B004A9BQMS?ref=nb_sb_ss_w_as-reorder-t1_ypp_rep_k0_1_24&&crid=176RHY6B92JBT&&sprefix=plumbcraft+toilet+fill+v A turn knob controls the water height.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
have you checked to see if you have turtles in the tank? One flush they could be in the water, another sitting above the water on a log or something.
Tru6 Restoration & Design |
^^^ Nah...they only sit above water if the sun is out....not the moon.
Almost Banned Once
A really big "load" could drag the water along behind it when you flush so it doesn't come back to the normal height.
(Think about the water level in the S bend) Does a further flush bring the water level up to normal?
- Peter |
Nope. I even tried pouring water in and it drained out which seems extra weird to me.
And be careful when you're picking wild mushrooms for culinary purposes.
Almost Banned Once
Is it possible you have a broken sewer pipe that's leaking into the ground? I really hope you don't.
- Peter |
This is strange. The level of water in the toilet should always be the same based on the curvature of the bowl and tube going up and over. It’s like a P-trap under a sink. It always stays the same.
Perhaps there is a crack in the toilet somewhere? Have you looked in the crawlspace? |
From time to time I'd find a low water level. Never figured out what causes it.
Sold: 1989 3.2 coupe, 112k miles |
my (idiotic) first thought was that a vacuum has formed,
Chris the more i learn, the less i know |
Evil Genius
Lasers?, Not on their heads, but they shoot from their eyes. ![]()
Life is a big ocean to swim in. Wag more, bark less.
Senior Member
Water. When the toilet fills up higher, it means there is more water in the bowl.
You're welcome. The turtle question is just silly.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Yeah, apparently, all I had to do was post about it, because I just went into the bathroom and the level is back at the norm.
Not silly...turtles know what a full moon looks like.
rotten support or movements may cause the wax ring to not seal properly. Is crawl space under the toilet accessible? Check for wet spots under there.
Banned
got a dog ?
they lower the level by drinking |
Make Bruins Great Again
The wax ring may be leaking?
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
