Flex Seal in a can...
I was thinking about spraying a screen door and rafting down the Nolichucky... or just stopping a minor leak around a skylight. Since Billy Mays died .... I don't trust TV pitchmen either .
Anyone used it... the stuff in the can that you spray on. Any other options or suggestions? Thanks!
Old 07-01-2022, 05:42 AM
Model Citizen
herr_oberst's Avatar
Those chuckleheads at Mythbusters made a dingy out of duct tape. Don't know how wooly the Nolichucky is, but you could try!
Old 07-01-2022, 05:46 AM
Back when I worked in a photo lab, processing film we had two film processors that the chemical tanks were made of a grey plastic that felt much like teflon. No glue would stick to it at all. PCV cement was as useless as Elmers glue on it, and would just peel off. We had a slow seep from one very minor crack near the top to the fluid level. We tried everything we could find. Finally the boss came in with a can of flexseal. It just made a mess on that plastic.
We ended up having to hire a plastic welder to come fix the slow leak, and a bigger leak cause by an idiot employee hammering on the side of the tank trying to get a threaded fitting off.
It may well work for your skylight. No real pressure to hold back, just a slow leak. Just mask off the parts you don't want covered in the stuff.
Old 07-01-2022, 06:20 AM
I would think that you'd want to spray from the outside, not the inside. If you spray from the inside, I think you'll just collect the water and eventually send it somewhere else both of which sound bad.
Old 07-01-2022, 06:41 AM
Throw it on the ground!
I tried this stuff last week in a failed attempt to coat some tiki torch canisters that were leaking. The citronella oil dissolved the flex seal stuff at the leak points. Nothing on the can warning was not to use on or how to clean up. One of ten ski torches failed immediately (to had some rust through holes). The others with slow leaks at the seams are holding up but I think it is only a matter of time before they shoot craps>
This stuff sprays on super thin. You have to spray multiple coats to get any kind of buildup.
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 07-01-2022, 06:47 AM
T77911S's Avatar
try HENRYS roof patch.
there are different types of it but dont know the difference.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-01-2022, 06:56 AM
TimBer's Avatar
I've never used it to stop a leak or seal anything, but I did use a couple coats on a pedal board I made out of a 2x4. I'm happy with the texture it provides as opposed to just spray painting it black.
"I aint pissing nothing away. I got a Porsche already; a 911 with a quadrophonic Blaupunkt"
- Ebby Calvin LaLoosh
Old 07-01-2022, 07:13 AM
Model Citizen
^. That's cool! Nice rig. I assume the Altoids can is for the wireless?
Old 07-01-2022, 07:15 AM
TimBer's Avatar
Just picks! Only picks! You will not find anything else in there other than picks!
It really is just picks in mine, but some have been know to put other stuff in there. Stuff that they may use in between sets.
Old 07-01-2022, 07:36 AM
My friends call me, Top
Skytrooper's Avatar
3 years ago when I rebuilt my wheelhorse mower deck, I sprayed the entire bottom. It is still doing a great job and nothing sticks to it.
Matt
'87 924S
Old 07-01-2022, 08:33 AM
rfuerst911sc's Avatar
Did you spray the Flex Seal on raw metal deck ? Or over primer/paint ? I am very surprised it can stand up to that harsh environment . Did you use clear or white or black ?
Old 07-01-2022, 09:25 AM
Platinum Member
dad911's Avatar
While we use it in new construction at underground foundation penetrations, I would not use it to fix a skylight. It's the flashing or the skylight itself.
Pitched shingle roof?
Old 07-01-2022, 09:26 AM
Deschodt's Avatar
That stuff is good. Had a leak in the garage roof (nail hole) and it has kept it dry for 6 years now (sprayed outside and inside). Same with another leak around one of those venting pipes in the roof, cured as well.. One of those rare times TV-informercial-crap works ! Within reason of course, it won;t fix a structural issue - and other brands work too...
Old 07-01-2022, 09:28 AM
Tried it on a fridge waterflow sensor for icemaker and door water thing. No dice and $18 wasted.
The part is a plastic box like thing that water flows through. It has electrical connections and somehow checks flow and possibly pressure. Part has leaks that appear to be from plastic cracking. Part is only about $40 but has been on backorder for a few months.
We currently have to buy ice at the 7-11 and get water from the tap.
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 07-01-2022, 10:04 AM
Old 07-01-2022, 10:12 AM
I forgot what those are used for. Please elaborate
1969 911E SOLD
2002 996 Cabrio
Old 07-01-2022, 10:19 AM
Platinum Member
dad911's Avatar
Device to constrain the molecules of liquid Dihydrogen monoxide when they chill enough to hook onto each other, forming a solid crystal hexahedron.
Old 07-01-2022, 11:01 AM
A930Rocket's Avatar
^^^ haha!
Old 07-01-2022, 02:10 PM
Skytrooper's Avatar
I primed it first. I used white Flex Seal. I am pretty surprised myself.
Matt
'87 924S
Old 07-01-2022, 02:48 PM
This is just a bandaid... gonna replace the pitched shingle roof soon. Sloped skylight now has a slight leak at the top that runs down the glass.... very minor, and it just started. Flex seal would be sprayed on the outside... until a "real fix". I need to get up there and take a look... could be the flashing or the skylight itself.
I hate ladders and climbing on my roof.... because I am NOT "roof girl" .
Thanks all!
Old 07-02-2022, 03:53 AM
