IS300's Avatar
cayenne choice
Hey Help
I have been looking Now At Cayennes... after the other thread.
would you give your opinions on what models to look for..
GTS or just an S or get a Turbo S
Also miles concerns and rebuilt cars?
thanks Anthony
Old 07-01-2022, 05:53 AM
Vulnerari Praesidio
Just my preferences:
2015 or later, S model with PASM...with 21 inch wheels...
mileage under 120k, ideally under 100k
no rebuilds...
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 07-01-2022, 06:02 AM
ckissick's Avatar
My 2013 diesel is pretty nice. Diesel now costs more than gas, but I get a little over 30 mpg on the highway. I can go just about 600 miles on a tank.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 07-01-2022, 08:02 AM
Bland
unclebilly's Avatar
Depends what you are looking for. A V6 is apparently rock solid reliable. We have a Cayenne S and it’s by far not the nicest example but it’s amazing to drive.
Here a photo I took this evening…
Old 07-21-2022, 08:53 PM
cantdrv55's Avatar
That’s a beauty
Old 07-21-2022, 08:54 PM
Send a message via AIM to fintstone
If you can find/afford one, I would look for a Turbo if looking for a 955. Both the aggressive looks and the better brakes. The turbocharged V8 also has a more robust engine oiling system...plus the additional horsepower. Pretty fast and great for towing.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-21-2022, 09:03 PM
Information Junky
island911's Avatar
The turbo and the S share the same brakes. Well, the turbos are red, the S silver paint.
Good point about the turbocharged V8 also having a more robust engine oiling system (piston squirters) although I see a lot of S V8's with well over 200k on the original engine. Mine is at 175k no problems so far.
The biggest "win" for the Turbo, is the high trim level as standard. I was lucky to find full leather and PASM in my S. My wife's is on coils, which really sucks on Seattle roads. Anyway, many, if not most, GTS's you see will not have full leather. (all GTS's PASM)
I prefer the throttle response over the freight-train (delayed) power of the turbos. Perhaps 5% better fuel economy, if that matters.
Old 07-21-2022, 09:46 PM
Shaun @ Tru6's Avatar
There are so many variable when deciding on a Cayenne from which body style do you like to its intended purpose: sports car vs. grocery getter vs. ...
I went with a 2010 GTS because I liked the 957 body style the best, it's a rocket ship and GTS seats are the best of any Cayenne. Love the wheels too. I drove an '08 S first and found it boring. I'll be posting about my experience over the last year and 17K miles soon. At 146.5K, driveshaft carrier bearing just went so doing that tomorrow.
Quick 30 hour drive out to CO to get a Scirocco in comfort
Tows 6K lb easily
Tru6 Restoration & Design
Old 07-22-2022, 03:55 AM
Originally Posted by Shaun @ Tru6 View Post
...At 146.5K, driveshaft carrier bearing just went so doing that tomorrow...
FYI, I have about 50K miles on the $6 "Jimmy" fix without issue. Took about 10 minutes and didn't even need a lift (just raised it with the air system).
Old 07-22-2022, 09:09 AM
I saw that video but I'm keeping the truck a long time, it's literally perfect for what I use it for. Even if I get the dreaded bore scoring (doubtful at this point), I'll just put another motor in it. $400 for the bearing fix is a bargain for not having to worry about ever again.
Old 07-22-2022, 09:46 AM
If it wore out once, it can do it again...and may have already failed once or more times for the previous owner. It appears the "fix" is actually more reliable than the factory version (which appears to be a very poor design and the weak point in the drive train). I have yet to see one that was repaired in this manner fail (and lots of folks have done it) as it is significantly stronger than the factory/original version. Your call.
Mine is a long-term car too. We have had it a decade and are closing in on 200k. Good luck with your's.
Old 07-22-2022, 10:06 AM
fastfredracing's Avatar
Turbo all day here. You get all the uplevel features, and not much on the road can pass you . I used to love leaving everything behind me at the stoplights
2nd choice would be the GTS
No left turn un stoned
Old 07-22-2022, 10:25 AM
Gus Berges's Avatar
Used to own a 955 series Turbo and it was a gremlins nightmare and a gas hog. Recently looked at a 958 series Turbo and is a significant improvement as long as you get a 2010 model to avoid the possibility of cylinder scoring. In my case, I'm about to close a deal on a 2011 (958 series) Turbo. It's a much better car overall, but I can see how others prefer the "rugged look" of the earlier versions and better off road capabilities. In my case, those two points do not apply and the price difference between a 2008 Turbo with 35K miles and a 2011 Turbo with 80K miles was just $2K.
Now: 2013 Cayenne GTS
Ex: 1999 C2, 2004 Cayenne Turbo, 2002 C4S, 1999 BMW M Z3 Coupe, 2013 Audi RS5
Old 07-22-2022, 11:25 AM
Jeff Alton's Avatar
I have had a 955 Turbo that we put just under 300K KMS on, and have had a 958 Turbo for the last 8 years. The 958 has a tune in it. It is one the my fave cars ever. It has 145K KMS and still drives and looks like new. It is crazy fast for a sport ute if you put your foot in it.
We also have a tuned Macan Turbo, which is more nimble, but does not have the room the Cayenne has.
Cheers
www.turn3autosport.com
Old 07-26-2022, 09:03 PM
ninelevenick's Avatar
We have both a 955 S and a 958 TT. The 955 is a great SUV. The 958 TT with PDCC and PTV is an excellent driving machine. A sport ute when we need it and a physics defying canyon carver when we want to have fun.
Old 07-26-2022, 09:37 PM
Zink Racer
A buddy has a 2010 GTS he bought with about 100k on it. Mechanically it has been ok. Shifting was weird and balky. New tires helped. Looks like as fronts/rears wear differently it can screw with the AWD system? His big issue has been water intrusion. Apparently firewall and sunroof drains are finicky and his was likely stored outside much of its previous life. Apparently a pretty well documented issue on Cayenne forums. He's had water coming in and settling in both the front floors and storage cubby in the rear.
Jerry
1964 356, 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, a couple of other 914's in various states of repair
Old 07-27-2022, 06:19 AM
The water intrusion is a very well known issue and easy to fix. The good thing about buying an older Cayenne is most things that go wrong are well documented. You can look for them during the purchase cycle and research them during ownership.
Old 07-27-2022, 07:10 AM
Information Junky
island911's Avatar
^ good points
The GTS is on air suspension. Tell him to have the alignment set at the level mostly driven. -from low to high the toe changes drastically.
Shifting problem is likely a sticky valve-body solenoid. Those (Japanese) gearboxes usually shift very smoothly.
Old 07-27-2022, 07:21 AM
Zink Racer
Originally Posted by island911 View Post
^ good points
Thanks. I will pass this along. He actually has a retired Porsche tech on his construction company payroll (long story) and they are planning on a full trans service soon. He has also chased down the leaks and seems to feel he has that sorted. I should say he loves the Cayenne, it is a beast and sounds fantastic. His looks just like Shaun's in silver.
Jerry
Old 07-27-2022, 07:51 AM
MAGA
Tim Hancock's Avatar
I did that to fix to my '08 daily driver about 3 years ago.... Works perfect and was quick and easy. It is silly to replace an otherwise perfectly good shaft.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 08-02-2022, 02:45 AM
