On the bright side you only have to replace the bad one. I wouldn't try to reinvent the wheel here. Do the same mod and hopefully it lasts another 30 years
dolor et pavor Copyright |
You do not have permissi
Is that even..
I'd be looking at someone's hide. A big one.
Meanwhile other things are still happening. |
When googling - I found this text from the mfr:
The BQC style breaker has a common trip as well as a rejection tab feature. These breakers are designed for use in BR type load centers and should be installed only in panel positions that have notched bus stabs that accommodate the rejection clip. Seems to me your stabs are not notched? https://www.dkhardware.com/br-1-50-amp-2-pole-and-2-20-amp-1-pole-bqc-common-trip-quad-circuit-breaker-bqc2502120-product-3141978.html?utm_source=google&utm_medium=shopping&utm_campaign=free_listings&gclid=Cj0KCQjwxIOXBhCrARIsAL1QFCaDzQkNbeiDUlt0DxrA VJpbkEAkZ3CH6pEYLUfnQhTPnxqCSZtaG9EaAnrCEALw_wcB
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Seems like they are notched.
![]() But what do I know. |
Notches are probably at the bottom where double ones are supposed to go. The rejection tabs (if those have them) are to keep you from doing just what they did...put more circuits in the box than it was designed for. It is really not an unheard-of practice to do this to make them fit (as in your box). If an inspector noted it on a house sale, you might have to fix (might not meet code in some places).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
