Arizona_928's Avatar
On the bright side you only have to replace the bad one. I wouldn't try to reinvent the wheel here. Do the same mod and hopefully it lasts another 30 years
dolor et pavor
Copyright
Old 07-27-2022, 12:47 PM
You do not have permissi
john70t's Avatar
Originally Posted by Arizona_928 View Post
Self tapping screws
Is that even..
I'd be looking at someone's hide. A big one.
Old 07-27-2022, 12:50 PM
MBAtarga's Avatar
When googling - I found this text from the mfr:
The BQC style breaker has a common trip as well as a rejection tab feature. These breakers are designed for use in BR type load centers and should be installed only in panel positions that have notched bus stabs that accommodate the rejection clip.
Seems to me your stabs are not notched?
https://www.dkhardware.com/br-1-50-amp-2-pole-and-2-20-amp-1-pole-bqc-common-trip-quad-circuit-breaker-bqc2502120-product-3141978.html?utm_source=google&utm_medium=shopping&utm_campaign=free_listings&gclid=Cj0KCQjwxIOXBhCrARIsAL1QFCaDzQkNbeiDUlt0DxrA VJpbkEAkZ3CH6pEYLUfnQhTPnxqCSZtaG9EaAnrCEALw_wcB
Mark
'83 SC Targa - since 5/5/2001
Old 07-27-2022, 02:18 PM
Seems like they are notched.
But what do I know.
Old 07-27-2022, 03:15 PM
Send a message via AIM to fintstone
Notches are probably at the bottom where double ones are supposed to go. The rejection tabs (if those have them) are to keep you from doing just what they did...put more circuits in the box than it was designed for. It is really not an unheard-of practice to do this to make them fit (as in your box). If an inspector noted it on a house sale, you might have to fix (might not meet code in some places).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-27-2022, 03:38 PM
