Sweet! I know a bunch of people in bike manufacturing and anodizing in Portland. I bet some of them contributed to this. Nice!
Growtec discs are nice as well.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Has 26mm tubeless tires (sworks turbo tubeless) so that helps too. Very stiff and just about 18lbs. Main thing i care about: i rode down the steep hill to my house in the rain today and braked casually from the hoods. |
Thanks for that info.
I've considered refitting my recumbent with disc brakes but haven't done so yet (would have to strip the paint to weld tabs for the rear and just don't want to deal with a repaint). Might be easier to build another bike... |
Does the fork have tabs for disc caliper? You really only need the front because the front is where it does the stopping. I hate disc brake squeal.
Parrothead member
Reminds me of that pink race car that's painted like a butchered pig!
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
![]() Some things just require pink socks too !
canna change law physics
The Rules
https://www.velominati.com/ Quote:
Rule 5 // Harden The **** Up. Rule 12 // The correct number of bikes to own is n+1.While the minimum number of bikes one should own is three, the correct number is n+1, where n is the number of bikes currently owned. This equation may also be re-written as s-1, where s is the number of bikes owned that would result in separation from your partner. Quote:
Rule 28// Socks can be any damn colour you like.White is old school cool. Black is cool too, but were given a bad image by a Texan whose were too long. If you feel you must go colored, make sure they damn well match your kit. Tip: DeFeet Wool-E-Ators rule.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 Last edited by red-beard; 06-10-2023 at 04:52 AM.. |
Setting up brakes on a 'bent is a bit different depending on how the bike is set up and where the CG is. My short-wheel-base bike needs equal braking effort front and rear or else the back end slides out. My old long-wheel-base bike would have the front slide out in a corner with too much braking effort up front. |
Almost Banned Once
Welding disk brake tabs onto a classic frame can be done safely but please don't over heat Chromoly.
![]() ![]() This is a classic frame with new disk brake tab drop outs. You can also get them to suit thru-axles. ![]() The whole bikes for drools ... lol ![]()
- Peter |
I do have v-brakes on my bike. |
I can stop now. Didnt make sense that in the wet i use one finger on mtb but cant stop at all on road bike - thats the bad sort of fear. |
