Computer Battery Question
Probably a dumb one, but can a 68Wh battery be replaced with a 62 Wh battery? This is a Dell Latitude. Voltages are the same, connections are the same, dimensions are the same, etc...
Looked on the Dell.com site and there was one comment saying one shouldn't go from a higher Wh to a lower Wh battery. If 68 to 42, sure, that makes sense. But would 6 Wh be enough to be an issue?
Thanks, Dave
Old 09-26-2023, 05:38 AM
It may well work, but battery time will be shorter than before.
Most people want a higher capacity battery for more time operating on battery.
Old 09-26-2023, 05:43 AM
Many laptops had the possibility of 2 different batteries with one being standard and the other being an optional upgrade.
eg - buy our laptop for $999 w/48Wh battery
or if you want longer battery life, $1199 with 64Wh battery!
Also, in the past it was a thing to update cell phones with larger capacity batteries to give you more battery life.
I don't think there's any issue with a different capacity battery being used as long as it fits and the voltages and connections are the same. I suppose it's possible that some devices may have some sort of intelligence that caused a problem, but I think that would be the exception rather than the rule.
Old 09-26-2023, 05:54 AM
id10t's Avatar
The BIOS may complain about it not being up to its coded-in spec
Also, form factors for batteries tend to vary slightly, even between similar dell models....
Old 09-26-2023, 06:10 AM
My machine didn't like the change. Won't charge the 62 Wh battery. Did get a bios error message. System didn't recognize the battery as OEM.
Old 09-26-2023, 07:38 AM
