Oven heating element in water
I need to boil about 50 gallons of water in a custom made tub and was thinking 1 or 2 oven heating elements would be good. Elements in the water, e- connections end mounted in a jig that would hang over the edge, safely out of the water.
Would that work? is there a better way?
Tru6 Restoration & Design |
Hmmm....almost sounds like an application for a heating element from a water heater....
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
My water heater thermostat is set for 125. Are water heater elements designed to go to 250ºF at a minimum? Oven would have a lot more surface area to get to boiling faster though that's not a big issue, that said, it won't be an insulated container so maximum heating is important.
Make your life easy. Use the advantages (lots) of a water heater element and avoid the pitfalls (multiple and high risk) of the oven element.
https://www.amazon.com/EWH-02-Electric-Heater-Tune-Up-Universal/dp/B08FHZT85Q/ref=sr_1_6?crid=2IEK3XCN2B8GJ&keywords=water+heater+element&qid=1698241583&sprefix=water+heater+%2Caps%2C108&sr=8-6 Or do it your way and become famous on YouTube.
Model Citizen
Why are you using electricity? Why not use fire?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Counterclockwise?
I would think you would need lots of heat and covered to make 50 gallons of water to boil.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
170 degrees is the highest I've seen for a water heater element.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
There is no way an oven element is designed to be used under water. I would use water heater elements. As long as you keep power to them, they will continue to heat. Now if they’re rated for that is another story. These are going to be a 208/230v element. Use at your own risk
Sent from my iPhone using Tapatalk |
You're building a still, aren't you?
Lots of information on those sites. https://www.homebrewtalk.com/threads/55-gallon-electric-brew-kettle.203011/ The consensus in this thread is 3 5500 w elements. Still a long time to heat that much "water" |
Element? Or thermostat? He won't need a thermostat, his heating element will be on continuously.
Can you do it outside or in a VERY well vented area?
propane tank crab boiler burner thing would certainly do it
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Model Citizen
very quick google search, water heating elements don't get very hot so a stove element would be best I think. Steve, have to do inside though I could use my Cerakote paint room that is vented of course. But, I have to make the bath out of plywood lined with EPDM so no fire.
Southern Class & Sass
Dixie Bradenton, FL 2013 Camaro ZL1 |
I wish you luck in your adventure.
I'll google more but if I had to guess, it's either a safety regulation thing or a lifetime thing, or both.
Home beer brewers boil so will look in that direction. From a beer forum: " The mythbusters boiled water in a hot water heater and it was really bad for the life of the element."
Thanks but my bath will be 7 feet long and 6 inches wide foot wide by 1 feet deep.
