LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
Shaun @ Tru6's Avatar
Oven heating element in water
I need to boil about 50 gallons of water in a custom made tub and was thinking 1 or 2 oven heating elements would be good. Elements in the water, e- connections end mounted in a jig that would hang over the edge, safely out of the water.
Would that work?
is there a better way?
Tru6 Restoration & Design
Old 10-25-2023, 06:11 AM
Hmmm....almost sounds like an application for a heating element from a water heater....
Old 10-25-2023, 06:29 AM
That's crazy talk, using an element from a 50 gal water heater would never work. The element would be sleepy under powered and it's not remotely designed for use in water.
Old 10-25-2023, 06:42 AM
My water heater thermostat is set for 125. Are water heater elements designed to go to 250ºF at a minimum? Oven would have a lot more surface area to get to boiling faster though that's not a big issue, that said, it won't be an insulated container so maximum heating is important.
Old 10-25-2023, 06:46 AM
Make your life easy. Use the advantages (lots) of a water heater element and avoid the pitfalls (multiple and high risk) of the oven element.
https://www.amazon.com/EWH-02-Electric-Heater-Tune-Up-Universal/dp/B08FHZT85Q/ref=sr_1_6?crid=2IEK3XCN2B8GJ&keywords=water+heater+element&qid=1698241583&sprefix=water+heater+%2Caps%2C108&sr=8-6
Or do it your way and become famous on YouTube.
Old 10-25-2023, 06:47 AM
Model Citizen
herr_oberst's Avatar
Why are you using electricity? Why not use fire?
Old 10-25-2023, 06:49 AM
Counterclockwise?
I would think you would need lots of heat and covered to make 50 gallons of water to boil.
Rod
1986 Carrera
2001 996TT
Old 10-25-2023, 06:50 AM
170 degrees is the highest I've seen for a water heater element.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 10-25-2023, 06:52 AM
DerkPerk's Avatar
There is no way an oven element is designed to be used under water. I would use water heater elements. As long as you keep power to them, they will continue to heat. Now if they’re rated for that is another story. These are going to be a 208/230v element. Use at your own risk
Old 10-25-2023, 06:54 AM
You're building a still, aren't you?
Lots of information on those sites.
https://www.homebrewtalk.com/threads/55-gallon-electric-brew-kettle.203011/
The consensus in this thread is 3 5500 w elements. Still a long time to heat that much "water"
Old 10-25-2023, 06:59 AM
Element? Or thermostat? He won't need a thermostat, his heating element will be on continuously.
Old 10-25-2023, 07:02 AM
Watts, not surface area, is what you need to look at.
Old 10-25-2023, 07:03 AM
id10t's Avatar
Can you do it outside or in a VERY well vented area?
propane tank crab boiler burner thing would certainly do it
Old 10-25-2023, 07:12 AM
Model Citizen
http://en.wikipedia.org/wiki/Rocket_stove
Old 10-25-2023, 07:16 AM
very quick google search, water heating elements don't get very hot so a stove element would be best I think. Steve, have to do inside though I could use my Cerakote paint room that is vented of course. But, I have to make the bath out of plywood lined with EPDM so no fire.
Old 10-25-2023, 07:26 AM
I have a 200,000 BTU wok burner. That would do something. But no fire.
Southern Class & Sass
Dixie's Avatar
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 10-25-2023, 07:40 AM
So a 3,500 Watt element gets to about 200F, and that's it? That's completely illogical.
I wish you luck in your adventure.
Old 10-25-2023, 07:42 AM
I'll google more but if I had to guess, it's either a safety regulation thing or a lifetime thing, or both.
Home beer brewers boil so will look in that direction.
From a beer forum: " The mythbusters boiled water in a hot water heater and it was really bad for the life of the element."
Old 10-25-2023, 07:52 AM
Originally Posted by Capt. Carrera View Post
Thanks but my bath will be 7 feet long and 6 inches wide foot wide by 1 feet deep.
Old 10-25-2023, 07:55 AM
