Run smooth, run fast
Aerosol paint nozzles that are clogged
I do all the things you're supposed to do and they still clog.
Asking the brain trust for some suggestions for solvents that might open them up... mineral spirits... acetone... gasoline... turpentine... sterno... 150 proof vodka?
- John "We had a band powerful enough to turn goat piss into gasoline." |
Banned
I have done the same. PITA. I've watched all the YouTube videos as well. Nothing seems to work. I end up tossing them and using one off anther can.
I've started to clean them right after use, before the paint can dry in them. The other problem is paint that I can't get out of the can no matter what nozzle I use. |
This is a big problem with the "spray in any position" cans. We used to just turn them upside down and blow out some of the propellant to clean the nozzles.
I had the problem a lot, but found a solution. I have a small glass jar of acetone on the work bench that I drop the nozzles in. If I've just used them successfully I only soak them a few minutes, then blow them out with compressed air. If paint has dried in them I soak them overnight, then blow them out.
^^^I never throw the nozzle away after a can expires, they go in the jar. The white males seem to be the most scarce. Some have been in there for years. I just reach for the ones on top with needle nose.
I'd like a rattle can shaker. The spinning type don't seem worthy but I haven't tried one. |
I scavenged a shaker device out of an old vibra chair recliner my dad had to make a paint can shaker out of it.
Haven't perfected it yet.
Scott '78 SC mit Sportomatic - Sold |
I see attachments for a Sawzall. IDT you need that much violence.
Keep your tips in a jar of mineral spirits.......you'll never have a problem.......
Old dog....new tricks..... |
Thanks for the tips... so it's either acetone or mineral spirits. Will probably try acetone first.
Mineral spirits are good for keeping the paint in them from drying and clogging. Acetone will dissolve the dried paint. I use acetone for everything only because it's easier than having two glass jars of flammable fluid sitting on my bench.
If ya don't want to use flammable acetone, I've found that non-acetone fingernail polish remover works great on removing & dissolving stuff ... and hasn't harmed any surfaces I've used it on. I've been using it for years on stuff .... including dried paint some jerk sprayed on my ex-g/f's white Lexus
![]() removes the pink polish from my toenails too ![]() |
I find Rustoleum to be the most difficult to deal with. It often dries in the valve in the top of the can. I wish they made much smaller, "single use" cans. Often the majority of the content in the full size cans is wasted, trapped behind that darn metal valve. Other brands don't seem to suffer this, but I find Rustoleum to be superior for most of what I need spray paint for.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
I have good luck wiping them clean with solvent. I rarely get a clogged one.
It seems be the last drip on the outlet that clogs up.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Evil Genius
Last couple days I've been shooting rattle cans of Plasta-Dip and Truck Bed Liner. Both pretty sticky stuff. On the can they mention soaking in solvent if clogged.
Life is a big ocean to swim in. Wag more, bark less. ![]() |
I've had cans of Behr paint clog up as I was spraying, very annoying.
"A little nonsense now and then is relished by the wisest men." Wonka |
Navin Johnson
You can also buy spares in all sorts of configurations.. male female, etc.
https://www.amazon.com/Spray-Can-Nozzle/s?k=Spray+Can+Nozzle
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I have been having problems with the cans plugging up. I bought 3 cans of John Deere black paint and the first one lasted about 5 seconds. The second was intermittent and I got maybe 25% - 50% of the product I paid for before it plugged up for good. The 3rd is on the shelf. I shake them before using and try to invert before finishing. I also stick my nozzles into solvent when done.
I have never had any problem with plugging on Krylon. |
I'm thinking of storing my rattle cans upside down as long as they have a cap. When paint pigments settle they settle all over the bottom and the ball can't get into the crease. If some of that sludge gets free and gets to the straw, you're done with that can.
Realistically, the sludge can get into places while the can is inverted as well. Best to agitate the cans periodically like turning bottles on champagne. Just one more thing to have to do. When they were 3 bucks ea who cared? |
Thread Tools | |
Rate This Thread | |
