LinkBack Thread Tools Rating: Thread Rating: 3 votes, 2.33 average.
Team California
speeder's Avatar
Ok, guys, I took the cover off of the unit that doesn’t run and I’m looking at the capacitors(?), which do not show any visible signs of failure like being swollen, etc.
Can anyone tell me where to check for power to the unit? Here are some photos I just took:
Old 09-13-2024, 05:15 PM
Team California
speeder's Avatar
Looks like there is no power at the switch inside of RV. The breakers are all in the “on” position and I’m not seeing a fuse anywhere on the unit. Not sure where to look now.
Old 09-13-2024, 05:50 PM
Take out the supply air grille assembly and look up inside. You’ll see the power wiring to what passes for a circuit board, which really is just old mechanical relays and the like.
Old 09-13-2024, 06:23 PM
Team California
speeder's Avatar
Do you mean the cover inside of the coach? I did remove it and all I saw were a couple of switches that the knobs attach to, nothing that looked like a circuit board. I can get some photos of that tomorrow.
Old 09-13-2024, 09:24 PM
Send a message via AIM to fintstone
Look in here for a control box (in front of the evaporator). It should have a thermostat with a sensor that goes into the evaporator.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-13-2024, 10:05 PM
Yes. Look up into the area Fint is pointing out, but from the inside of the coach. Or, pull off the sheet metal on the roof. Either way, it’s in there somewhere.
Old 09-14-2024, 03:29 AM
Team California
speeder's Avatar
Ok, and what should I be looking for when I find it? Remember, I'm getting nada power too the switch. Thanks again.
Denis
Old 09-14-2024, 10:31 AM
There will be power coming from the RV to the A/C unit. Test that first. If you have power getting to the unit from the RV, check to see if the control board is calling for cooling, for the fan to run, etc. according to what the thermostat is set to do.
Lots of videos on YouTube showing how to do all that, if you’re not familiar with A/C units in general.
Old 09-14-2024, 10:55 AM
Look for the data plate that tells you what model A/C unit you have.
Find the wiring diagram, it will look something like this:
There is probably a nine pin connector that plugs into what passes for a circuit board in these things, where you can test the functions you need to test.
Old 09-14-2024, 11:05 AM
You should have a panel with circuit breakers and fuses. This uses 120V (gen or shore) to run the roof system and 12v (vehicle battery) to control it. Are you sure you have both 120AC and 12VDC at the terminal bock from the breaker and fuse respectively?
Old 09-14-2024, 11:22 AM
If you have checked input power, this is where the control box typically is (you can check the AC and DC here where it comes into the system):
From this video which shows basic troubleshooting of the unit.
https://youtu.be/3VckFAXg1CY?feature=shared
Old 09-14-2024, 12:21 PM
Team California
speeder's Avatar
Thanks! Here’s the view from inside with the cover off:
Old 09-14-2024, 06:03 PM
Best bet is to measure at the relay that is probably better accessed from the top. You should definitely have one to run the compressor and probably another to run the fan. They would most likely be controlled by 12v in (to turn them off and on) and pass 115 AC. Do you have either 12v or 115 at either of the switches/wires inside?
Before that, I would look for the 12v fuse that provides power (if there is no power at the switches). It should be with the other fuses (fuse block) ...assuming your system is typical.
Old 09-14-2024, 10:37 PM
Ahh, now you’re getting somewhere!
Break out the multimeter, consult the wiring diagram and start testing.
Old 09-15-2024, 05:08 AM
canna change law physics
red-beard's Avatar
The capacitors "look" OK, but they are rusted. "While you're in there" I'd go ahead and replace those after you solve the power issue.
James
Red-beard for President, 2020
Old 09-16-2024, 04:34 AM
Team California
speeder's Avatar
Ok, back on this thing. I pulled it inside out of the heat and just came down from the roof. There is nothing behind the front of the sheet metal other than the big cord that runs from the temp control to the other unit maybe(?) It disappears under the aluminum body/roof going towards the front. I still have no idea what I’m supposed to be testing or looking for power:
Old 09-30-2024, 03:15 PM
I'm working on it.
Pictures are ****, trying to figure out what goes where.
Is that a piece of Romex I'm seeing in the first and third photos above? From where to where?
You ever find a wiring diagram label or model #/serial # label on the thing anywhere?
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 10-02-2024, 10:10 AM
Capacitors:
1 compressor run
2 fan
3 compressor start
House wiring to the unit should be behind one of the selector switches on the grille assembly inside the unit. Open up behind them to look. Start with the one on the left, first.
Old 10-02-2024, 10:40 AM
red-beard's Avatar
Why not upgrade to an inverter AC unit
https://www.amazon.com/dp/B089MYDLTY/
Less power, quieter
James
Old 10-03-2024, 10:14 AM
Team California
speeder's Avatar
Less power, quieter
If the unit was completely shot and needed to be replaced, I'd definitely be looking at options and that one looks good. As it is, I have so many projects going that the RV is not a big priority and I just want to get what is on it working if possible. Still, I appreciate it, James.
Denis
Old 10-03-2024, 10:19 AM
