Question for the Pond Experts - Can I reduce Flow?
My pond pump is too powerful. I tried a smaller pump and it puts out too little. My current pump is creating a waterfall that is almost like Niagra and way too loud.
I'm wondering if it will damage the pump for me to add an in-line ball valve where I can adjust the water pressure.
Any advice would be appreciated.
Vern
Old 09-12-2024, 03:45 PM
Maybe put a T in the line to the waterfall and direct the second line back into the pond?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 09-12-2024, 03:59 PM
Yea, diverter T with an orifice in one of the output lines. Maybe make a simple flow control.
Old 09-13-2024, 06:20 AM
I like the above idea of a diverter valve. If it's a valve then you can "tune" it as 1990C4S said.
The only other thing that I could think of which may be problematic would be adjusting the voltage or current to the pump. I know that in some circumstances reduced voltage or current will slow something down without causing issues, but then in other cases, it can harm equipment. I'm not sure how to determine if your pump is the former or latter.
Old 09-13-2024, 06:35 AM
Counterclockwise?
Why not just a valve on the line?
Rod
1986 Carrera
2001 996TT
Old 09-13-2024, 06:41 AM
id10t's Avatar
Putting a PWM on the power circuit may be able to do that for you, though I think they only work w/ DC stuff... all I know about 'letrissity is that it is to be respected 'cause it can kill you ded
Old 09-13-2024, 06:44 AM
Would a valve that limits flow stress the motor with backpressure?
Old 09-13-2024, 06:58 AM
Counterclockwise?
Not sure, but we do this everyday with a well or lake pump.
Rod
1986 Carrera
2001 996TT
Old 09-13-2024, 07:51 AM
vash's Avatar
I got a "B" in fluid dynamics. from memory, you won't hurt your pump. I remember everything you add downstream of the pump will add friction. elbows, T's, length of pipe. you could T it off and run a secondary outlet underwater somewhere for added current.
I think if you choke it off with a ball valve type thing, the water exiting that valve will increase in velocity (velocity = flow/area - I think). might be even more noise and excitement.
poof! gone
Old 09-13-2024, 08:08 AM
Agreed, reducing aperture will increase pressure/speed.
Old 09-13-2024, 08:49 AM
There you have it, a man speaking from experience. This sounds like the way to go. (assuming pressure/speed increase isn't a problem).
Old 09-13-2024, 08:50 AM
Counterclockwise?
I nothing but .....when using the sprinkler with my lake pump I adjust the height by closing my valve a bit.
Rod
1986 Carrera
2001 996TT
Old 09-13-2024, 08:58 AM
Evil Genius
Rusty Heap's Avatar
simple. speed controller on motor.
Life is a big ocean to swim in.
Wag more, bark less.
Old 09-13-2024, 09:03 AM
wdfifteen's Avatar
The greater the head pressure, the harder the pump has to work.
At the very least, throttling the line will use more electricity because the pump is working harder.
Working harder means more heat, which will shorten the motor's life. Significantly? That would be up to you.
Worst case scenario is the flow is so restricted, there isn't enough water flowing through the pump to keep the motor cool. That will cost ya.
Adding a tee and a line back to the pond with a valve in it that would control the bypass flow would be the best option.
Old 09-13-2024, 09:57 AM
You do not have permissi
john70t's Avatar
If it's purpose is to put O2 into the water and clean it up, consider an aeration diffuser system instead of sprinkler fountain.
Makes more sense to move air instead of water.
Old 09-13-2024, 12:42 PM
This is what I got and will install this weekend. I'm thinking I only need to restrict by about 25% and this will be the easiest solution. Time will tell if it's hard on the motor but they are not extremely expensive - about $150
Old 09-13-2024, 01:09 PM
I have an air pump and a diffuser. This pump is recirculating the pond water to a filter and then back to the pond via waterfall. If the ball valve doesn't work (i.e., increasing pressure & sound) then I will divert the water to another area of the pond. I already have two 1.5" lines feeding the waterfall and moving one of them to feed directly into the pond is an easy fix. If I go that route, I have simply added a shutoff valve and that is no big.
Old 09-13-2024, 01:15 PM
That's what I was thinking (in much less detail). Seems to me that the best solution is to be able to vary the pump volume/time (why I was thinking about vary the voltage/current) (AKA "speed controller on motor" as Rusty Heap said).
Old 09-13-2024, 01:17 PM
Evil Genius
Rusty Heap's Avatar
pick your wattage.......... $30.
https://www.amazon.com/s?k=ac+motor+speed+controller&crid=2ZVMV8FVREFI7&sprefix=ac+motor+speed+controlle%2Caps%2C194&ref=nb_sb_noss_2
Old 09-13-2024, 08:18 PM
Restricting the discharge flow will reduce
the load on the motor.
At deadhead conditions, the HP requirement
it at it's very lowest.
But it can also cause low-flow recirculation
in the impeller.
That causes hydraulic turbulence and vibration
and could reduce the life of the bearings and impeller.
But on a low-energy pond pump
it probably wouldn't be that big of a deal.
As mentioned above, the best way to do it would be
to reduce the speed of the pump.
Old 09-14-2024, 01:41 AM
