Question for the Pond Experts - Can I reduce Flow?
My pond pump is too powerful. I tried a smaller pump and it puts out too little. My current pump is creating a waterfall that is almost like Niagra and way too loud.
I'm wondering if it will damage the pump for me to add an in-line ball valve where I can adjust the water pressure. Any advice would be appreciated. Vern |
Maybe put a T in the line to the waterfall and direct the second line back into the pond?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Yea, diverter T with an orifice in one of the output lines. Maybe make a simple flow control.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
I like the above idea of a diverter valve. If it's a valve then you can "tune" it as 1990C4S said.
The only other thing that I could think of which may be problematic would be adjusting the voltage or current to the pump. I know that in some circumstances reduced voltage or current will slow something down without causing issues, but then in other cases, it can harm equipment. I'm not sure how to determine if your pump is the former or latter.
Counterclockwise?
Why not just a valve on the line?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Would a valve that limits flow stress the motor with backpressure?
Counterclockwise?
Not sure, but we do this everyday with a well or lake pump.
I got a "B" in fluid dynamics. from memory, you won't hurt your pump. I remember everything you add downstream of the pump will add friction. elbows, T's, length of pipe. you could T it off and run a secondary outlet underwater somewhere for added current.
I think if you choke it off with a ball valve type thing, the water exiting that valve will increase in velocity (velocity = flow/area - I think). might be even more noise and excitement.
poof! gone |
There you have it, a man speaking from experience. This sounds like the way to go. (assuming pressure/speed increase isn't a problem).
Counterclockwise?
I nothing but .....when using the sprinkler with my lake pump I adjust the height by closing my valve a bit.
Evil Genius
simple. speed controller on motor.
Life is a big ocean to swim in. Wag more, bark less.
At the very least, throttling the line will use more electricity because the pump is working harder. Working harder means more heat, which will shorten the motor's life. Significantly? That would be up to you. Worst case scenario is the flow is so restricted, there isn't enough water flowing through the pump to keep the motor cool. That will cost ya. Adding a tee and a line back to the pond with a valve in it that would control the bypass flow would be the best option.
You do not have permissi
If it's purpose is to put O2 into the water and clean it up, consider an aeration diffuser system instead of sprinkler fountain.
Makes more sense to move air instead of water.
Meanwhile other things are still happening. |
I have an air pump and a diffuser. This pump is recirculating the pond water to a filter and then back to the pond via waterfall. If the ball valve doesn't work (i.e., increasing pressure & sound) then I will divert the water to another area of the pond. I already have two 1.5" lines feeding the waterfall and moving one of them to feed directly into the pond is an easy fix. If I go that route, I have simply added a shutoff valve and that is no big.
Evil Genius
pick your wattage.......... $30.
https://www.amazon.com/s?k=ac+motor+speed+controller&crid=2ZVMV8FVREFI7&sprefix=ac+motor+speed+controlle%2Caps%2C194&ref=nb_sb_noss_2
Restricting the discharge flow will reduce
the load on the motor. At deadhead conditions, the HP requirement it at it's very lowest. But it can also cause low-flow recirculation in the impeller. That causes hydraulic turbulence and vibration and could reduce the life of the bearings and impeller. But on a low-energy pond pump it probably wouldn't be that big of a deal. As mentioned above, the best way to do it would be to reduce the speed of the pump. Last edited by red 928; 09-14-2024 at 01:44 AM.. |
