TerryBPP's Avatar
I dont want a hood scoop! Help
I have been working on a 318i M10 turbo for some time now and have run into a small problem. I used the stock manifold, flipped it upside down, and made an adapter for the T3 flange. I made the adapter as low as possible, theres just enough room to tighten the nuts.
Problem is the turbo touches the hood when its closed. Its going to burn the hell out of it. So I need to raise the hood in that section (4" x 4"). I dont really want to put a ricer scoop on one side of the hood. Anyone see any nice looking way to do this?
Old 10-13-2005, 10:02 AM
Super Moderator
cstreit's Avatar
Can you subtly flare the hood a bit and add some cermic insulating material? It's a lot of work but will save you the hood scoop.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-13-2005, 10:07 AM
pwd72s's Avatar
Instead of a scoop, how about a "bubble"? Those beautiful long nosed cars of the early 60's did it all the time...hoods with mysterious bumps on them...usually for carb clearance.
Old 10-13-2005, 10:09 AM
TerryBPP's Avatar
I would love to do this but I need to find a hood that I can cut the bubble off of and weld it to mine. Any ideas? Didnt a little Dodge car have a turbo bumo?
Old 10-13-2005, 10:15 AM
pwd72s's Avatar
If doing it yourself, I'd suggest making a rough design out of cardboard...then visit a Detroit car wrecking yard & start matching curves...you might find what you're looking for on a crumpled trunk lid corner, a fender curve, wherever. If that panel has been hit, the wrecked-em yard would sell it for next to nothing...
Old 10-13-2005, 10:25 AM
MAGA
Tim Hancock's Avatar
Terry, I would think about cutting a circle in some particle board then throwing a sheet of old truck tire inner tube on it. Next find a hard large ball (bowling ball maybe?) then carefully postion the hood over the hole and smack the ball with a large mallet thus cold forming the bubble into the hood. If the paint is warmed first it may not even crack. I would experiment on a scrap pc of sheet metal first though and be sure to size the hole properly.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 10-13-2005, 10:28 AM
Formerly bb80sc
Vipergrün's Avatar
Actually, I do not think a little scoop like on the WRX's looks too bad. IMHO, a bubble may look a little odd, but you could probably find one to use from like a Turbo Mitsu Eclips or similar, didn't they have one?
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 10-13-2005, 10:32 AM
TerryBPP's Avatar
LOL, I always wondered why that guy purposely put that turbo that high. He could have obviously cut atleast a foot off of it.
Anyway, I just came across a cool little scoop.
Tim, you're a nut.
Old 10-13-2005, 10:42 AM
304065's Avatar
Terry, I would steer clear of a power bulge. The whole POINT is to make people think that you have a bone stock 98 hp four-banger under there!
If it were German taxi yellow with a 324d badge, more the better.
http://home.att.net/~jroal/jay/bmw.htm
http://home.att.net/~jroal/jay/clints.html
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 10-13-2005, 10:49 AM
TerryBPP's Avatar
Ahh, you found my reference site. Only difference is he mounted hi turbo below the mani. I couldn't do that because my is so low ,bilstien shocks, ie springs, ie sways, 3" drop +/-. The outlet to the turbo would hit the ground, lol. You also need an insane amount of intercooler and charge piping. Here is mine:
It sits about 2" higher than in the pic.
With the stance, brakes, 15" Kosei wheels (14 lbs!) this thing looks anything but stock.
Old 10-13-2005, 10:58 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Any chance of actually raising the entire hood? Put on a side panels where the hood meets the fenders.
BTW - I like the lil scoop you found.
Michael D. Holloway
https://5thorderindustry.com/
Old 10-13-2005, 11:03 AM
Terry, is it hitting the outer skin of the hood or some of the inner bracing? Would some sort of grill-type panel painted with hi-temp paint and flush (or close to flush) mounted work?
Several of the FWD Chryco cars used a low profile "bulge"; Daytonas and Shadows had them as well as a couple of the Omni hatchback cars probably some others.
Old 10-13-2005, 11:04 AM
TerryBPP's Avatar
I wish it was hitting a brace. Sitting on the skin.
I thought about cutting a duct and just putting a mesh on it but I fear the turbo would cook that too.
Old 10-13-2005, 11:21 AM
TerryBPP's Avatar
I think this is what you where thinking?:
Old 10-13-2005, 11:24 AM
Moses's Avatar
Go with something classy like this;
Old 10-13-2005, 11:25 AM
Moses's Avatar
Didn't the Ford Probe have a small bump in the hood? Might be a suitable graft.
Old 10-13-2005, 11:31 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
eagle talons have a small bump.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 10-13-2005, 11:32 AM
Yeah something like that to keep the lines clean. Since it's hitting the outer skin, even something like that wouldn't work because engine movement would bust it out. Looks like either a bulge or scoop is the way to go.
A NACA duct would work, but would probably look stupid with a turbo in the middle of it.
Old 10-13-2005, 11:33 AM
MAGA
Originally posted by TerryBPP
Tim, you're a nut.
Actually I was being serious, but obviously there are plenty options available if you are going to cut the hood.
0% Liberal
Old 10-13-2005, 11:35 AM
TerryBPP's Avatar
Jesus, I thought you were kidding. How tall a ladder do I stand on?
Old 10-13-2005, 11:57 AM
