white87911's Avatar
Test for Engineers and Machinists or "Smart" People
Hello Everyone,
Here is a little test for anyone here whos is familur with "3 view drawings" The kind of blueprint you used to get when you were a machinist and you were to make a part.
Basically you get a "Top", "Front" and "Side" view of a part and from that you could make anything.
Here is a little refresher on the system.
"Solid Lines" are edges you can see in the view.
"Dashed Lines" are edges that are "internal" or "hidden" like a hole.
So here is your test. The following image is the "Front" AND the "Top" view of a part. Your job is to determine the "Side" view.
Remember the "rules" from above.
Good Luck!
"Coffee is for Closers"
"Push the button Max!!!"
Old 10-27-2005, 06:51 PM
on-ramp's Avatar
i only see a square within a square. where are the hidden lines you mentioned?
Old 10-27-2005, 07:04 PM
Flatbutt1's Avatar
I can't attach the drawing but it would be a rectange or a square with two dashed lines running parallel to one another at a distance equal to the size of the inner square. I'm guessing this is a square donut
big blue tricycle
stare down the darkness and watch it fade
Old 10-27-2005, 07:07 PM
nostatic's Avatar
is it a duck?
Old 10-27-2005, 07:11 PM
white87911's Avatar
There is no dashed lines in the "top" or "front" view, there may, or may not, be in the side you that you are to provide.
Flattbutt1, you are wrong, but your answer is normally the 1st response to this question.
nostatic, I really like you, but no luck on the Duck!
Old 10-27-2005, 07:16 PM
Flatbutt1's Avatar
perhaps the little square is raised above the base square? Or is that the usual 2nd guess?
big blue tricycle
Old 10-27-2005, 07:32 PM
AFJuvat's Avatar
It would be a cube, with a smaller cube/square projection of undetermined length projecting from the top and left side when viewed in side view
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-27-2005, 07:37 PM
nostatic's Avatar
is it Tab's mom?
Old 10-27-2005, 07:39 PM
PRO Motorsports
Tyson Schmidt's Avatar
I would guess that it would be a pyramid with the top cut off. Only way I know how to describe it. But how would one determine it's height?
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 10-27-2005, 08:19 PM
WOODPIE's Avatar
I think the side view would be a "L" shape, laid on its side.
Old 10-27-2005, 08:31 PM
craigster59's Avatar
Re: Test for Engineers and Machinists or "Smart" People
I can spell "familiar". Do I get any points for that?
Old 10-27-2005, 08:38 PM
B58/732
BlueSkyJaunte's Avatar
_______
ΜΟΛΩΝ ΛΑΒΕ
Old 10-27-2005, 09:08 PM
Banned
Mulhollanddose's Avatar
All I see is a picture of Calvin pissing on the DNC...meh
Old 10-27-2005, 09:12 PM
Moses's Avatar
Just a square.
Old 10-27-2005, 09:18 PM
WOODPIE's Avatar
Yeah, its like BlueSky's example, but both verticle and horizontal lines are solid, and of equal length.
Old 10-27-2005, 09:30 PM
Side view would be a right triangle with another smaller one sticking out from the center, or in 3-d it would look like a square block cut in 1/2 along the diagonal with another 1/2 sized cut the same way place long sides together and centered.
It's late, I hope you can visualize my description; what do I win?
Old 10-27-2005, 09:32 PM
Like this...
Old 10-27-2005, 09:44 PM
Chuck Moreland's Avatar
This is the side view:
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-27-2005, 09:46 PM
vott does ziss do?
ronin's Avatar
symmetrical, of course
Old 10-27-2005, 09:54 PM
vott does ziss do?
ronin's Avatar
928ram, you beat me to it. looks like you had the same basic idea
Old 10-27-2005, 09:56 PM
