Re: Re: Re: Re: Why is the center of the earth magma?
Originally posted by Mulhollanddose
Its is the atheists you should fear. Unquestionably the greatest human monsters and sadists the world has seen....Their descendents are the Democrats.
going... going... GONE! over the right field wall!
Can you even type this stuff with a straight face?
Old 02-17-2006, 09:52 AM
IROC's Avatar
Ahhhh, but the difference is that the atheists weren't monsters *because* they were atheists - they were just monsters that happened to not believe in god(s). Religious fanatics are monsters "in the name of their god(s)". :>)
Thanks, Souk. Faster. Very interesting.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-17-2006, 09:59 AM
least common denominator
scottmandue's Avatar
Because when they tried chocolate pudding it didn't work so well...
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 02-17-2006, 10:13 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Someday the magna y'all will call homestead.
LMAO, seriously.... sometimes I cant tell when you are serious or joking =)
Old 02-17-2006, 10:39 AM
Bill is Dead.
cashflyer's Avatar
Originally posted by TerryBPP
It can't be free energy so I don't get it.
But it IS free energy.
In the late 1800s, it was discovered that the earth's energy was nearly depleated. The president contracted Nikola Tesla to use his time travel technology to go back to the time of creation. Once there, Nik installed a radically new device into the core of the earth. This device, which harnessed both zero point energy and perpetual motion, was forever after known as "The Gerorator".
Smaller versions are available for your home from distributors nationwide. A nominal $9 fee may apply. Offer void in Kentucky.
Old 02-17-2006, 10:51 AM
Registered abUser
TerryH's Avatar
It's about 4,000 mile to the Earths core. I think the deepest anyone has drilled is about 8-9 miles. It can safely be assumed that no one knows with absolute certainty what is inside our planet. There is belief by some scientists that the liquid part is nuclear. Much speculation abounds about Earth while we are off looking at Pluto.
'81 911SC Coupe SOLD
Old 02-17-2006, 11:17 AM
johncj8989's Avatar
Ask Dr. Evil... he is an expert on boiling hot mag-MA.
Chaos, panic and disorder . . . my work here is done
Current Stable:
Maserati GranTurismo S
Range Rover Autobiography
Various Porsches ~ in pieces
Old 02-17-2006, 11:22 AM
Not true. Several explorers have been down there. They reported that in fact they did not find mere Magma.....what they found was Smagma
Warren & Ron, may you rest in Peace.
Old 02-17-2006, 11:30 AM
White and Nerdy
Tervuren's Avatar
Pressure heats. The deeper in the Earth you go, the more the outside presses in, causing pressure. When you compress something, it heats. The heat is caused then by its own mass. The energy is provided by gravity.
Shadilay.
Old 02-17-2006, 11:48 AM
Liquid hot MAG - MA
Old 02-17-2006, 12:03 PM
Yes, but didn't the free generator guy prove that there is no gravity?
Gary Fisher 29er
1995 Miata Sold
1984 944 Sold
Old 02-17-2006, 12:23 PM
ckissick's Avatar
One reason: radioactivity.
A few hundred years ago, scientists began wondering how the earth could be only about 5000 years old, as the Bible says. So someone used thermodynamics and rates of heat loss to estimate that the earth, since it still has liquid magma, must be at least a few hundred thousand years old. The Vatican did not like this, but there you are.
Later estimates using rates of mountain uplift and erosion came up with an age of the earth of a few million years. More huffing and puffing at the Vatican.
Then along came the astronomers who suggested ages of the universe, solar system and earth on the order of billions of years. Now, many scientists, as well as the Vatican, were more confused than ever. How could this be? The earth does not have near enough stored heat to remain somewhat liquid.
Then one of the early radioactivity researchers provided the answer. He calculated that a reasonable amount of plutonium, etc. would emit enough radioactive decay to keep the liquid mantle liquid. (The solid inner core is solid because the great pressure overcomes the heat needed to melt rock. Same reasoning as to why you need to boil pasta longer in Denver-lower pressure, lower boiling temp.)
All that plutonium and other very heavy molecules were created not in the Big Bang, but in a supernova of our original sun, about 5 billion years ago. That early supernova provided all the raw materials to create our solar system, as well as left over gases that were used to re-form our current user-friendly sun.
It's a good thing our mantle is liquid. Because it is liquid, it moves. This movement creates our magnetic field, which shields the earth from the solar winds. Without the shield, our atmosphere would be stripped away, and earth would look a lot like Mars. Mars is solid because it's so much smaller than earth, and radioactive decay was not sufficeint to make up for the smaller size. Mars has no moving magma, no magnetic field, and its atmosphere is only 1% as thick as earth's.
Charlie
1966 912 Polo Red
1950 VW Bug
1983 VW Westfalia; 1989 VW Syncro Tristar Doka
Old 02-17-2006, 01:29 PM
stevepaa's Avatar
Very informative, thanks Charlie.
steve
old rocket inguneer
Old 02-17-2006, 01:36 PM
Me like track days
Craig 930 RS's Avatar
The center of the Earth is one very large, red swollen clitoris.
It's hot.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-17-2006, 02:29 PM
ckissick's Avatar
Jeeze, Craig, I write that brilliant scientific thesis and all you have to say is something about a clitoris? You must have been a joy in the class room.
Charlie
1966 912 Polo Red
1950 VW Bug
Old 02-17-2006, 03:21 PM
So earthquakes are really orgasms?
Old 02-17-2006, 03:32 PM
Me like track days
Sure.
You got yer friction, cracks, a big hole, the depth of a tremor.....it's all there.
Old 02-17-2006, 03:41 PM
ckissick's Avatar
Settle down, class!
Charlie
1966 912 Polo Red
1950 VW Bug
Old 02-17-2006, 03:51 PM
one of gods prototypes
bell's Avatar
all you need to do is watch the movie "the core".......it'll explain everything
this was a joke.....DO NOT watch "the core", it'll make you stupid
Brought to you by Carl's Jr.
Old 02-17-2006, 05:10 PM
Don Plumley's Avatar
Originally posted by widebody911
I thought it was leftover heat from when the planet was expelled from the cloaca of the Flying Spaghetti Monster?
Close, I believe it is a mass of boiling Spaghetti Sauce. Scientists might confuse this with Magma, given the similarity in color and consistency. I think the Creator intelligently designed this yummy food source in case we ran out. It would not be a meatball because that is part of Him.
Don Plumley
M235i
Old 02-17-2006, 05:16 PM
