Computer..no more click
My click sound vanished. Windows Me programming. Cindy did a clean up including:
Delete: emails cookies temporary files Run: adaware spybot PC on point also the normal clean up-scan-defrag Then signed back into the usual stuff So, why no audio click? Is there a reset? Thanks in advance. Paul
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
In XP it's Start> Settings> Control Panel> Sound and Audio Devices> Sounds. Scroll down in the sounds box to Windows Explorer> Start Navigation. Click "browse" which will bring up a list of sounds avalable, which you may have to try a few to right one (It's WindowsXPstart.wav in XP, but look for the obvious like click.wav)
ME should be similar navigation to the "sounds" settings though it may have it's own heading under control panel. Also there should be a "sound schemes" box which if set to "Windows Default" will bring back all the OEM sounds. |
Did you check your hearing aid battery?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
lost click
Cindy here. We have Windows ME. I got to the Sounds and Multia Media box in the control panel. I set it on Windows Default, but I still don't hear a click. Any other suggestions?
Get a Mac,
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Do you hear any other sounds? If not, could be that the master volume may be muted.
-Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Re: lost click
2000 is an ok replacement, but Xp is pretty good if your system can swallow it. |
Senior Member
Click on Control panel, then System, then Device manager
Check to see if you have any yellow "!" marks beside any of the devices listed there. If you do then something has a driver issue. Other than that Z's comment about the master volumn may be the problem. Best way to fix this is to save everything you need, then format it and install W2000 or XP. ME is a terrible OS...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Did you disconnect the speakers? If so, make sure the speakers are plugged into the correct port on the computer.
Are you able to hear any other sounds from the computer? |
one of gods prototypes
![]() we say that to my dad alot
Brought to you by Carl's Jr. |
We're just having gangs of fun here...played around until ALL the other sounds have fun new tones...things like startup & shutdown, spell check over, etc. But no click. Frankly, it's getting close to the time to toss this ancient machine, but were hoping it would hang in there until the new Microsoft VISTA comes along...
Bell, may you never need a hearing aid. Problems begin when you confuse your hearing aids with your suppositories...
Make Bruins Great Again
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
big blue tricycle stare down the darkness and watch it fade |
