"Bite my shiny, metal..."
...bender!
I got the holes drilled (weekend before last, actually) and got everything operational. I still need to finish off the welding on the pedestal, but it works well as-is. I can easily un-bolt it and stash it out of the way.
I bought dies for 1-1/2" square and 1-1/2" round material
There's a slight learning curve to bending tubing - it's a good idea to buy a little extra!
Old 05-15-2006, 12:35 PM
greglepore's Avatar
I've used the same bender in a friend's shop. Nice.
Agree w/the learning curve, especially in terms of where the center of the bend ends up, and which way everything gets laid out on multiple bend pieces, hence the advice to chalk it out on the floor and mark the tubing with arrows.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-15-2006, 12:54 PM
Cars & Coffee Killer
legion's Avatar
And I thought this would be about the new episodes of Futurama...
5 liters of VVT fury now
-Chris
Old 05-15-2006, 12:55 PM
Awesome. Have you bent any round pipe? If so how's it look?
Warren & Ron, may you rest in Peace.
Old 05-15-2006, 12:57 PM
techweenie's Avatar
+1
...after that false alarm a few weeks back, I noticed the rumor has surfaced again.
:-0
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
legion's Avatar
Originally posted by techweenie
+1
:-0
Cartoon Network had something about it on their Adult Swim "bumps". Purposefully vague.
-Chris
Old 05-15-2006, 01:00 PM
You do not have permissi
john70t's Avatar
OOOOh, Toys. Is it Christmas already? Let's predict the "pay-for-itself" schedule.
Thom, add a foot diameter (with braces) onto the base of the post platform along with deep bolt fasteners- if you want to get crazy with it. The concrete is pretty smooth but looks soft(micro cracks already?).
Old 05-15-2006, 01:02 PM
The concrete has a couple of light cracks on the surface, but I used 1/2" rebar on 18" centers, and #6 (IIRC) wire mesh, so it's not going anywhere.
To fasten the plate, I made a 4" 'column' of 5/8-11 nuts welded together and glued them in with Hilti epoxy. The plate is big enough for the bender to stand on it's own when not in use. I welded nuts on the bottom of the top plate and the bender bolts to that. I need to (ahem) "adjust" the other two holes in the plate so I can get those bolts in. I have some allen bolts to thread in when I don't have the bender installed, and the embedded fasters are recessed so the the allen bolts will sit flush with the concrete.
Old 05-15-2006, 01:14 PM
john70t's Avatar
Temporary, effective, and modular. Nice.
Old 05-15-2006, 01:31 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Wanna' fab me up some custom headers?
Black Cars Matter
Old 05-15-2006, 03:05 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
noooooooice
I need a cat bypass
Old 05-15-2006, 06:22 PM
Senior Member
Very nice! I have a bender as well but its still sitting in storage. Always enjoyed working with one.
Need to win the lotto to buy the 25 acre place I need with a LARGE workshop...
Old 05-15-2006, 10:08 PM
TerryBPP's Avatar
Any ripples on the inside of the curves after bending?
Old 05-16-2006, 06:24 AM
No ripples - that's the beauty of this type of bender.
The die used for square tubing does create an indentation on the inside of the bend, on purpose - the metal has to go somewhere.
Old 05-16-2006, 07:02 AM
If your doing anything complex, consider a copy of the Bend tech software. The cheapest version is something like 60.00 bucks.
Check out:
http://www.2020softwaresolutions.com/index.htm
I have no affiliation, just a happy customer. I used it to nail a bunch of tricky bends for a tube frame car I built a while back. Takes all of the guesswork out of things.
Vin
Old 05-16-2006, 08:32 AM
