I show about a litre (quart) oil over filled on my Mazda 2.2 l engine. What happens to the engine/oil in this case? Is it possible for the oil to surge up the dipstick tube and spill out during higher revs? I guess I should just drain the extra oil out.
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
This will often lead to leaks at either end of the crank on the main bearing seals. On the front, it will make a mess. On the back, it could get all over the clutch, requiring a clutch replacement. It won't come up out of the dipstick tube; that would be the least of your problems if it did.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Senior Member
Some engines the crank will hit the oil sitting in the bottom, causing damage at times. Best to drain or suck a bit out and get it closer to the right level. How far over the max mark is it showing now?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
